Originally posted by spknapp
View Post
Not all devices are updating on CT-80
Originally posted by spknapp View PostI am having to bounce the plugin every few days. Any progress on fixing this problem?
ThanksOriginally posted by kingfetty View PostYeah, sorry, had some issues come up, I'm back home now and will get back to hunting this bug.Steve
(System configuration is in my profile)
Originally posted by spknapp View PostEric - any progress? Is there anything I can do to help out?Originally posted by kingfetty View PostI can't seem to recreate the issues, but I run CT-30s and CT-50s. I'm wondering if it's an issue specific to the CT-80s.
Anyone else using CT-80 and having issues?
I have yet to receive an email from Radio Thermostat saying that they have lost communication with my thermostat during any period when your plugin loses communication. If I unplug the thermostat and leave it powered off for a couple of days, RTCOA sends me an email to let me know the thermostat is offline.
Simply disabling/enabling your plugin it happily communicates with my CT-80 again. This leads me to suspect a problem with the communication failure recovery routine(s) in your plugin.
Please, I paid good money in good faith in your software. This problem has gone on long enough. I need to get this fixed so I can trust your plugin to control my CT-80 thermostat. Again, please let me know what I can do to help you get this problem resolved in the quickest manner.Steve
Originally posted by spknapp View PostEric - I am still experiencing this problem using the latest version of the plugin 1.0.17267.124. I have mitigated it a little by using the "Jon00 Enable/Disable Plugin Utility" and bouncing the plugin daily at 1:00 AM, but I find that your plugin can still lose communication with my thermostat even between 1:00 AM and 5:45 AM (when I have HomeSeer HS3 tell it to adjust the thermostat for my "Wake Up" routine), let alone any other time of the day, too.
Ok, let me see what I can find.
New version .138 has been posted with some tweaks to help with stability, especially on linux systems. I moved to a newer HttpClient for doing the REST calls. This new httpclient also reuses TCP connections instead of needing to teardown everything and rebuild it. This should help as well. I also changed the autodiscovery to work better on linux systems.
Let me know if this helps with your stability issues.
Originally posted by kingfetty View PostNew version .138 has been posted with some tweaks to help with stability, especially on linux systems. I moved to a newer HttpClient for doing the REST calls. This new httpclient also reuses TCP connections instead of needing to teardown everything and rebuild it. This should help as well. I also changed the autodiscovery to work better on linux systems.
Let me know if this helps with your stability issues.Steve
Still losing communications with CT-80
Eric - on 12/17/2017 12:08:19 PM I updated to and started version 1.0.17351.159 of your plugin. As you can see, your plugin has lost communications with my CT-80 again. There is nothing in the log from your plugin all day on the 20th except for my events changing the setpoint. There were two messages days earlier of the type "RadioThermostat
Thermostat with IP: 172.16.0.136 is not responding after 4 retries, please check the thermostat", one of them 12/17/2017 4:03:17 PM and the other 12/18/2017 5:26:01 AM.
I am in the process of updating to version 1.0.17353.162 right now and will report on its operation.
How can I help debug this problem?
ThanksSteve
Again, just shortly after I updated to 1.0.17353.162
I updated to 1.0.17353.162 at 4:33:00 PM on 12/23/2017 and your plugin stopped talking to my thermostat at 11:05:47 PM. The only entries for your plugin or my thermostat are when I have events set up to change the setpoint. Interestingly the setpoint changed at the HomeSeer device Heat Setpoint THERMOSTATS-Q18 but of course did not reflect any changes on the thermostat itself.
What can I do to help debug this?
ThanksSteve
Originally posted by spknapp View PostI updated to 1.0.17353.162 at 4:33:00 PM on 12/23/2017 and your plugin stopped talking to my thermostat at 11:05:47 PM. The only entries for your plugin or my thermostat are when I have events set up to change the setpoint. Interestingly the setpoint changed at the HomeSeer device Heat Setpoint THERMOSTATS-Q18 but of course did not reflect any changes on the thermostat itself.
Originally posted by kingfetty View PostAnd if I remember correctly, as soon as you stop/start the plugin it starts working again?
ThanksSteve
Originally posted by spknapp View PostThat's right. I don't know your code, but I'm thinking you're doing something different with establishing communication at the start of the plugin than when re-establishing communication possibly after an error?
- On start create a WebClient object
- Create a timer object
- Every time the timer triggers it will tell the web client to issue HTTP GET to each of the IP address of the Thermostats to get the current state of things
- If a homeseer device gets a control command to change a setting it will tell the WebClient to issue an HTTP POST command with the appropriate JSON values to change the setting on the thermostat.
This works for everyone else except your setup for some reason. I had suspected that maybe the webclient I was using was hanging up for some reason on your system so on the latest round of updates I switched out the web client to a different newer version in the .net framework 4.6.
At this point I'm convinced that it's something specific to your setup that's not interacting well with this logic as all others are working ok.
Would it be possible to install homeseer on a test computer for a while and install the plugin there to see if it's system specific?
