How do I confirm voice commands?
    The Voice Commands documentation describes types of commands that will get a confirmation question if the associated option is set. When the system gives the confirmation question, what do I tell it to confirm the command? I've tried "yes", "confirm", "go", "do it", "engage", "make it so", repeating the command, "confirm" and then repeating the command, and pretty much every other response I can think of that would make sense. All it says in return is essentially "that device was not found", implying that it's looking for a device called "confirm" or whatever other answer I give.
    If it makes a difference, I'm using the API call given by Sgt. Shultz: /JSON?request=voicecommand&phrase={command}. Am I using it wrong? I haven't found anything in the forums or the documentation about this issue, but it seems hard to believe that nobody else has run into this.
