I just installed a new HS-WD200+ Dimmer Switch and noticed that the top led when the dimmer is set to full brightness does not light up white like the others do. I should note that I haven't set it up with z-wave yet. Would this make a difference? Seems that it shouldn't. Any thoughts on this are much appreciated....Rick
Issue with HS-WD200+ Dimmer Switch?
