My entry door has a schlage deadbolt along with a door sensor. I've been using the built in 30 sec autolock.
Sometime, I would unlock the deadbolt but not exit and forget about it and when I finally leave and close the door, often times the deadbolt would start locking during the process causing me to slam the deadbolt.
There are two problems with this, first is the security concern where if the deadbolt slams the door remain insecure, and second is damaging the door jam.
I played around with an event that would only lock the door when the door sensor is closed but it doesn't quite work.
Has anyone setup a similar event?
