Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old June 12th, 2018, 02:50 PM
weslsew weslsew is offline
Seer
ZW1001 GE/Jasco receptacle - no factory reset?
I have a z-wave wall outlet GE/Jasco branded, model no. ZW1001. I had trouble with my network due to a z-wave device going bad, and did a reset of the controller without removing this device. I was able to factory reset my other devices and include them to my new network, but there doesn't seem to be a factory reset for this device. I called Jasco who said there is not a way, and they will just exchange it for a new updated device. Has anyone ran into this issue? Luckily i only have one of these, I can't imagine having to replace a whole house full of outlets in the event a controller goes bad.
Old June 12th, 2018, 02:56 PM
cowinger cowinger is offline
Seer Master
Quote:
You should still be able to exclude it from the controller. It will still reset it. That way you can include it back into the new network. I created a 10 ft extension cord that has connectors on the black, white and ground and that way you can exclude it next to the controller and then re-include it and then it can be re-installed anywhere.
Old June 13th, 2018, 09:20 AM
Seer
Quote:
you can exclude it from a network that it isn't a part of? I did try that but nothing happened
Old June 13th, 2018, 09:26 AM
rprade's Avatar
rprade rprade is online now
OverSeer
You can Exclude a Z-Wave device from any controller. When it is excluded, it will be reset. When you go through the exclusion, it should be noted in the controller dialog. If it is a device not paired with the controller, it will not show a node number, but it will still say a device was excluded. If you exclude a device that has already been excluded, it will still indicate that a device is being excluded, just no node number. Since your device is not Z-Wave plus, it will have to be close (4-10 feet unobstructed) in order to be seen by the controller.
Randy Prade
Aurora, CO
Prades.net
Old June 13th, 2018, 09:38 AM
NetworkGuy NetworkGuy is online now
Seer Deluxe
Correct, you should be able to first exclude from your new network, then you should be able to include into the new network.
Old June 13th, 2018, 09:46 AM
Seer Deluxe
That's an interesting idea, thanks. On the flip side, if you have a Z-Net, you could power it up via a USB battery and place it next to the device you're trying to exclude/include.
Old June 15th, 2018, 07:49 AM
Seer
Quote:
That was it. I pulled it out of the wall and wired it to an old lamp cord next to the controller and it was able to be excluded. Jasco support didn't mention that
HTML code is Off
Factory Reset gconey Z-NET 9 April 19th, 2018 02:14 PM
factory reset.. hockeypuck HomeTroller Zee 2 January 14th, 2016 08:36 AM
Factory reset? Silentcossack HomeTroller Zee 5 November 10th, 2013 11:40 AM
Factory Reset HSM100? spicuzza HSM100™ Multi-Sensor 1 April 29th, 2010 03:17 PM
