Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLiTunes (3P)
BLiTunes (3P) Discussion of BLiTunes plug-in
Old March 22nd, 2010, 08:52 PM
aslamma
Guest
Posts: n/a
General questions
Would I just disable the homeseer plugin and simply add this one and all of my current hstouch projects should work as usual? Is it that simple?
I am having issues with the homeseer plugin and am hoping this works bettter. Would it be possible that this plugin is more reliable and effective than homeseers?
Old March 22nd, 2010, 08:59 PM
Rupp's Avatar
Rupp Rupp is offline
That depends on the issues you are having with the HomeSeer plugin.
-Rupp
Old March 23rd, 2010, 09:14 AM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Brian - If Bob (Blade) used the HomeSeer music API to create this plug-in, it should work properly with HSTouch. I have not tested it myself... good question for Bob.
Old March 23rd, 2010, 09:37 AM
Blade's Avatar
Blade Blade is offline
I did not use the HomeSeer music API
Cheers,
Bob
Old March 23rd, 2010, 04:03 PM
rjh's Avatar
rjh rjh is offline
Can you tell me what issues you are currently seeing? I posted a new build not long ago (2.5.0.9) that has all open issues fixed (that I am aware of).
Old March 23rd, 2010, 05:31 PM
aslamma
Guest
Posts: n/a
My question was related in part to the new build (2.5.0.9) and the old build. From what I can see, iTunes is tricky and HomeSeer is not the software to have problems with it. I was wondering if this plugin would be an alternate option.
As far as the new build, I have an open ticket on it (2.5.0.9). It fixed my previous issue with repeat not working. But upon install, it continuously think there is a new library and keeps trying to reload the library. The band aid fix is to turn off the switch that reloads the library, but that is not great since I guess I need to reload HomeSeer any time I make a change to iTunes (not sure if there is a way to reload the library manually).
Old March 25th, 2010, 06:03 PM
Blade's Avatar
The only way you will determine if the plugin will work for you is to give it a try.
Old December 9th, 2011, 09:19 PM
Loup's Avatar
Loup Loup is offline
Hi, I try blitunes but I can join my list. in the option, I can not change "library" why?
