Hello,
i want to use as an additional system "Homematic" to control my heating system and some lights. Homematic is a very popular home control system in Germany.
A command like this
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->http://XX.YYY.XY.XY/config/xmlapi/statelist.cgi
creates a file as you can see in the attachment.
Now my question:
How can I read some of this values, like the temperature, with a script and send this value to HomeSeer.
Is there anybody who can help me?
I hope so;-)
Thank you for your support and excuse me for my bad english.
Bye
Darklord
<statelist><device name="Heizung Kueche" ise_id="3034" unreach="false" sticky_unreach="false" config_pending="false"><channel name="Heizung Kueche:0" ise_id="3035"><datapoint name="BidCos-RF.HEQ0080017:0.UNREACH" type="UNREACH" ise_id="3048" value="false" valuetype="2" timestamp="1284116921"><datapoint name="BidCos-RF.HEQ0080017:0.STICKY_UNREACH" type="STICKY_UNREACH" ise_id="3044" value="false" valuetype="2" timestamp="1284116921"><datapoint name="BidCos-RF.HEQ0080017:0.CONFIG_PENDING" type="CONFIG_PENDING" ise_id="3036" value="false" valuetype="2" timestamp="1284116921"><channel name="He[/code]<statelist><device name=" heizung="" kueche="" ise_id="3034" unreach="false" sticky_unreach="false" config_pending="false"><channel name="Heizung Kueche:0" ise_id="3035"><datapoint name="BidCos-RF.HEQ0080017:0.UNREACH" type="UNREACH" ise_id="3048" value="false" valuetype="2" timestamp="1284116921"><datapoint name="BidCos-RF.HEQ0080017:0.STICKY_UNREACH" type="STICKY_UNREACH" ise_id="3044" value="false" valuetype="2" timestamp="1284116921"><datapoint name="BidCos-RF.HEQ0080017:0.CONFIG_PENDING" type="CONFIG_PENDING" ise_id="3036" value="false" valuetype="2" timestamp="1284116921"><channel name="Heizung Kueche.1: Messwerte" ise_id="3052"><datapoint name="BidCos-RF.HEQ0080017:1.TEMPERATURE" type="TEMPERATURE" ise_id="3054" value="22.200000" valuetype="4" timestamp="1284116907"><datapoint name="BidCos-RF.HEQ0080017:1.HUMIDITY" type="HUMIDITY" ise_id="3053" value="59" valuetype="16" timestamp="1284116907"><datapoint name="Temp Soll Kueche" type="" ise_id="1519" value="0.000000" valuetype="4" timestamp="1284116907"><datapoint name="Ventilstellung Kueche" type="" ise_id="1520" value="0.000000" valuetype="4" timestamp="1284116907"><datapoint name="Temp Min Kueche" type="" ise_id="2721" value="0.000000" valuetype="4" timestamp="1284116688"><datapoint name="Temp Max Kueche" type="" ise_id="1510" value="23.100000" valuetype="4" timestamp="1284116676"><datapoint name="Luftfeuchte Min Kueche" type="" ise_id="1513" value="0.000000" valuetype="4" timestamp="1284116688"><channel name="Heizung Kueche.2: Thermostat" ise_id="3055"><datapoint name="BidCos-RF.HEQ0080017:2.SETPOINT" type="SETPOINT" ise_id="3058" value="0.000000" valuetype="4" timestamp="1284116688"><datapoint name="BidCos-RF.HEQ0080017:2.ADJUSTING_COMMAND" type="ADJUSTING_COMMAND" ise_id="3056" value="0" valuetype="16" timestamp="1284116778"><device name="Heizung Kueche: Stellantrieb" ise_id="2999" unreach="false" sticky_unreach="false" config_pending="false"><channel name="Heizung Kueche: Stellantrieb:0" ise_id="3000"><datapoint name="BidCos-RF.HEQ0082355:0.UNREACH" type="UNREACH" ise_id="3013" value="false" valuetype="2" timestamp="1284116921"><datapoint name="BidCos-RF.HEQ0082355:0.STICKY_UNREACH" type="STICKY_UNREACH" ise_id="3009" value="false" valuetype="2" timestamp="1284116921"><datapoint name="BidCos-RF.HEQ0082355:0.CONFIG_PENDING" type="CONFIG_PENDING" ise_id="3001" value="false" valuetype="2" timestamp="1284116921"><channel name="Heizung Kueche.3: Stellantrieb" ise_id="3017"><device name="HM-CCU-1 System" ise_id="1389"><channel name="Zentralennetzteil" ise_id="1390"><datapoint name="System.System:1.U_SOURCE_FAIL" type="U_SOURCE_FAIL" ise_id="1401" value="false" valuetype="2" timestamp="1284116921"><datapoint name="System.System:1.LOWBAT" type="LOWBAT" ise_id="1393" value="false" valuetype="2" timestamp="1284116921"><datapoint name="System.System:1.U_USBD_OK" type="U_USBD_OK" ise_id="1405" value="true" valuetype="2" timestamp="1284116921"><device name="HM-RCV-50 BidCoS-RF" ise_id="1011"><channel name="HM-RCV-50 BidCoS-RF:0" ise_id="1012"><channel name="Anwesend" ise_id="1014"><datapoint name="BidCos-RF.BidCoS-RF:1.PRESS_LONG" type="PRESS_LONG" ise_id="1016" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:1.PRESS_SHORT" type="PRESS_SHORT" ise_id="1017" value="" valuetype="2" timestamp="0"><channel name="Schlafen" ise_id="1018"><datapoint name="BidCos-RF.BidCoS-RF:2.PRESS_LONG" type="PRESS_LONG" ise_id="1020" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:2.PRESS_SHORT" type="PRESS_SHORT" ise_id="1021" value="" valuetype="2" timestamp="0"><channel name="Heizperiode" ise_id="1022"><datapoint name="BidCos-RF.BidCoS-RF:3.PRESS_LONG" type="PRESS_LONG" ise_id="1024" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:3.PRESS_SHORT" type="PRESS_SHORT" ise_id="1025" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:4" ise_id="1026"><datapoint name="BidCos-RF.BidCoS-RF:4.PRESS_LONG" type="PRESS_LONG" ise_id="1028" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:4.PRESS_SHORT" type="PRESS_SHORT" ise_id="1029" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:5" ise_id="1030"><datapoint name="BidCos-RF.BidCoS-RF:5.PRESS_LONG" type="PRESS_LONG" ise_id="1032" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:5.PRESS_SHORT" type="PRESS_SHORT" ise_id="1033" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:6" ise_id="1034"><datapoint name="BidCos-RF.BidCoS-RF:6.PRESS_LONG" type="PRESS_LONG" ise_id="1036" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:6.PRESS_SHORT" type="PRESS_SHORT" ise_id="1037" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:7" ise_id="1038"><datapoint name="BidCos-RF.BidCoS-RF:7.PRESS_LONG" type="PRESS_LONG" ise_id="1040" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:7.PRESS_SHORT" type="PRESS_SHORT" ise_id="1041" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:8" ise_id="1042"><datapoint name="BidCos-RF.BidCoS-RF:8.PRESS_LONG" type="PRESS_LONG" ise_id="1044" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:8.PRESS_SHORT" type="PRESS_SHORT" ise_id="1045" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:9" ise_id="1046"><datapoint name="BidCos-RF.BidCoS-RF:9.PRESS_LONG" type="PRESS_LONG" ise_id="1048" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:9.PRESS_SHORT" type="PRESS_SHORT" ise_id="1049" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:10" ise_id="1050"><datapoint name="BidCos-RF.BidCoS-RF:10.PRESS_LONG" type="PRESS_LONG" ise_id="1052" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:10.PRESS_SHORT" type="PRESS_SHORT" ise_id="1053" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:11" ise_id="1054"><datapoint name="BidCos-RF.BidCoS-RF:11.PRESS_LONG" type="PRESS_LONG" ise_id="1056" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:11.PRESS_SHORT" type="PRESS_SHORT" ise_id="1057" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:12" ise_id="1058"><datapoint name="BidCos-RF.BidCoS-RF:12.PRESS_LONG" type="PRESS_LONG" ise_id="1060" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:12.PRESS_SHORT" type="PRESS_SHORT" ise_id="1061" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:13" ise_id="1062"><datapoint name="BidCos-RF.BidCoS-RF:13.PRESS_LONG" type="PRESS_LONG" ise_id="1064" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:13.PRESS_SHORT" type="PRESS_SHORT" ise_id="1065" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:14" ise_id="1066"><datapoint name="BidCos-RF.BidCoS-RF:14.PRESS_LONG" type="PRESS_LONG" ise_id="1068" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:14.PRESS_SHORT" type="PRESS_SHORT" ise_id="1069" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:15" ise_id="1070"><datapoint name="BidCos-RF.BidCoS-RF:15.PRESS_LONG" type="PRESS_LONG" ise_id="1072" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:15.PRESS_SHORT" type="PRESS_SHORT" ise_id="1073" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:16" ise_id="1074"><datapoint name="BidCos-RF.BidCoS-RF:16.PRESS_LONG" type="PRESS_LONG" ise_id="1076" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:16.PRESS_SHORT" type="PRESS_SHORT" ise_id="1077" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:17" ise_id="1078"><datapoint name="BidCos-RF.BidCoS-RF:17.PRESS_LONG" type="PRESS_LONG" ise_id="1080" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:17.PRESS_SHORT" type="PRESS_SHORT" ise_id="1081" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:18" ise_id="1082"><datapoint name="BidCos-RF.BidCoS-RF:18.PRESS_LONG" type="PRESS_LONG" ise_id="1084" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:18.PRESS_SHORT" type="PRESS_SHORT" ise_id="1085" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:19" ise_id="1086"><datapoint name="BidCos-RF.BidCoS-RF:19.PRESS_LONG" type="PRESS_LONG" ise_id="1088" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:19.PRESS_SHORT" type="PRESS_SHORT" ise_id="1089" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:20" ise_id="1090"><datapoint name="BidCos-RF.BidCoS-RF:20.PRESS_LONG" type="PRESS_LONG" ise_id="1092" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:20.PRESS_SHORT" type="PRESS_SHORT" ise_id="1093" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:21" ise_id="1094"><datapoint name="BidCos-RF.BidCoS-RF:21.PRESS_LONG" type="PRESS_LONG" ise_id="1096" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:21.PRESS_SHORT" type="PRESS_SHORT" ise_id="1097" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:22" ise_id="1098"><datapoint name="BidCos-RF.BidCoS-RF:22.PRESS_LONG" type="PRESS_LONG" ise_id="1100" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:22.PRESS_SHORT" type="PRESS_SHORT" ise_id="1101" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:23" ise_id="1102"><datapoint name="BidCos-RF.BidCoS-RF:23.PRESS_LONG" type="PRESS_LONG" ise_id="1104" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:23.PRESS_SHORT" type="PRESS_SHORT" ise_id="1105" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:24" ise_id="1106"><datapoint name="BidCos-RF.BidCoS-RF:24.PRESS_LONG" type="PRESS_LONG" ise_id="1108" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:24.PRESS_SHORT" type="PRESS_SHORT" ise_id="1109" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:25" ise_id="1110"><datapoint name="BidCos-RF.BidCoS-RF:25.PRESS_LONG" type="PRESS_LONG" ise_id="1112" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:25.PRESS_SHORT" type="PRESS_SHORT" ise_id="1113" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:26" ise_id="1114"><datapoint name="BidCos-RF.BidCoS-RF:26.PRESS_LONG" type="PRESS_LONG" ise_id="1116" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:26.PRESS_SHORT" type="PRESS_SHORT" ise_id="1117" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:27" ise_id="1118"><datapoint name="BidCos-RF.BidCoS-RF:27.PRESS_LONG" type="PRESS_LONG" ise_id="1120" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:27.PRESS_SHORT" type="PRESS_SHORT" ise_id="1121" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:28" ise_id="1122"><datapoint name="BidCos-RF.BidCoS-RF:28.PRESS_LONG" type="PRESS_LONG" ise_id="1124" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:28.PRESS_SHORT" type="PRESS_SHORT" ise_id="1125" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:29" ise_id="1126"><datapoint name="BidCos-RF.BidCoS-RF:29.PRESS_LONG" type="PRESS_LONG" ise_id="1128" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:29.PRESS_SHORT" type="PRESS_SHORT" ise_id="1129" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:30" ise_id="1130"><datapoint name="BidCos-RF.BidCoS-RF:30.PRESS_LONG" type="PRESS_LONG" ise_id="1132" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:30.PRESS_SHORT" type="PRESS_SHORT" ise_id="1133" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:31" ise_id="1134"><datapoint name="BidCos-RF.BidCoS-RF:31.PRESS_LONG" type="PRESS_LONG" ise_id="1136" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:31.PRESS_SHORT" type="PRESS_SHORT" ise_id="1137" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:32" ise_id="1138"><datapoint name="BidCos-RF.BidCoS-RF:32.PRESS_LONG" type="PRESS_LONG" ise_id="1140" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:32.PRESS_SHORT" type="PRESS_SHORT" ise_id="1141" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:33" ise_id="1142"><datapoint name="BidCos-RF.BidCoS-RF:33.PRESS_LONG" type="PRESS_LONG" ise_id="1144" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:33.PRESS_SHORT" type="PRESS_SHORT" ise_id="1145" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:34" ise_id="1146"><datapoint name="BidCos-RF.BidCoS-RF:34.PRESS_LONG" type="PRESS_LONG" ise_id="1148" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:34.PRESS_SHORT" type="PRESS_SHORT" ise_id="1149" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:35" ise_id="1150"><datapoint name="BidCos-RF.BidCoS-RF:35.PRESS_LONG" type="PRESS_LONG" ise_id="1152" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:35.PRESS_SHORT" type="PRESS_SHORT" ise_id="1153" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:36" ise_id="1154"><datapoint name="BidCos-RF.BidCoS-RF:36.PRESS_LONG" type="PRESS_LONG" ise_id="1156" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:36.PRESS_SHORT" type="PRESS_SHORT" ise_id="1157" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:37" ise_id="1158"><datapoint name="BidCos-RF.BidCoS-RF:37.PRESS_LONG" type="PRESS_LONG" ise_id="1160" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:37.PRESS_SHORT" type="PRESS_SHORT" ise_id="1161" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:38" ise_id="1162"><datapoint name="BidCos-RF.BidCoS-RF:38.PRESS_LONG" type="PRESS_LONG" ise_id="1164" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:38.PRESS_SHORT" type="PRESS_SHORT" ise_id="1165" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:39" ise_id="1166"><datapoint name="BidCos-RF.BidCoS-RF:39.PRESS_LONG" type="PRESS_LONG" ise_id="1168" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:39.PRESS_SHORT" type="PRESS_SHORT" ise_id="1169" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:40" ise_id="1170"><datapoint name="BidCos-RF.BidCoS-RF:40.PRESS_LONG" type="PRESS_LONG" ise_id="1172" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:40.PRESS_SHORT" type="PRESS_SHORT" ise_id="1173" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:41" ise_id="1174"><datapoint name="BidCos-RF.BidCoS-RF:41.PRESS_LONG" type="PRESS_LONG" ise_id="1176" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:41.PRESS_SHORT" type="PRESS_SHORT" ise_id="1177" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:42" ise_id="1178"><datapoint name="BidCos-RF.BidCoS-RF:42.PRESS_LONG" type="PRESS_LONG" ise_id="1180" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:42.PRESS_SHORT" type="PRESS_SHORT" ise_id="1181" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:43" ise_id="1182"><datapoint name="BidCos-RF.BidCoS-RF:43.PRESS_LONG" type="PRESS_LONG" ise_id="1184" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:43.PRESS_SHORT" type="PRESS_SHORT" ise_id="1185" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:44" ise_id="1186"><datapoint name="BidCos-RF.BidCoS-RF:44.PRESS_LONG" type="PRESS_LONG" ise_id="1188" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:44.PRESS_SHORT" type="PRESS_SHORT" ise_id="1189" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:45" ise_id="1190"><datapoint name="BidCos-RF.BidCoS-RF:45.PRESS_LONG" type="PRESS_LONG" ise_id="1192" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:45.PRESS_SHORT" type="PRESS_SHORT" ise_id="1193" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:46" ise_id="1194"><datapoint name="BidCos-RF.BidCoS-RF:46.PRESS_LONG" type="PRESS_LONG" ise_id="1196" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:46.PRESS_SHORT" type="PRESS_SHORT" ise_id="1197" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:47" ise_id="1198"><datapoint name="BidCos-RF.BidCoS-RF:47.PRESS_LONG" type="PRESS_LONG" ise_id="1200" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:47.PRESS_SHORT" type="PRESS_SHORT" ise_id="1201" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:48" ise_id="1202"><datapoint name="BidCos-RF.BidCoS-RF:48.PRESS_LONG" type="PRESS_LONG" ise_id="1204" value="" valuetype="2" timestamp="0"><datapoint name="BidCos-RF.BidCoS-RF:48.PRESS_SHORT" type="PRESS_SHORT" ise_id="1205" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:49" ise_id="1206"><datapoint name="BidCos-RF.BidCoS-RF:49.PRESS_LONG" type="PRESS_LONG" ise_id="1208" value="" valuetype="2" timestamp="0"> <datapoint name="BidCos-RF.BidCoS-RF:49.PRESS_SHORT" type="PRESS_SHORT" ise_id="1209" value="" valuetype="2" timestamp="0"><channel name="HM-RCV-50 BidCoS-RF:50" ise_id="1210"></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></datapoint></datapoint></channel></channel></device></datapoint></datapoint></datapoint></channel></device></channel></datapoint></datapoint></datapoint></channel></device></datapoint></datapoint></channel></datapoint></datapoint></datapoint></datapoint></datapoint></datapoint></datapoint></channel></datapoint></datapoint></datapoint></channel></channel></datapoint></datapoint></datapoint></channel></device></statelist>
A command like this
Now my question:
I hope so;-)
Bye
Darklord
