I have a problem that occasionally a plug-in crashes---when it does (and this occurs with at least two different plug-ins) the system displays a modal pop-up saying something to the effect of a problem has occurred. Do you want to send an error report.
As far as Homeseer is concerned, the plug-in is still active (i.e. the process is still in memory) so it does not attempt to restart it. It knows something is amiss (there are messages in the log that the plug-in is not responding), but I must manually dismiss the dialog box before the plug-in will restart.
I also (once or twice quite some time ago) had the same thing happen with Homeseer itself---and again it wouldn't restart until I manually cleared the dialog box.
Is there some system setting somewhere that I am missing that will resolve this issue? This is running on a Hometroller S4 box (so Windows XP embedded).
