Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLiTunes (3P)
BLiTunes (3P) Discussion of BLiTunes plug-in
Old June 15th, 2016, 02:57 PM
Mitch Mitch is offline
Initial install issue ++++
after entering the license code for your plugin I get
WARNING: Failed getting InterfaceStatus from BLiTunes - the interface was not found in the list of active interfaces, the list may need to be refreshed.
I also cannot login into your board please activate my user account
mg@cecg.com
If there is any doc for setting up the plugin please let me know.
also trying to figure out which plugin is best for my application
If you wis to call it is 609-758-1111 ext1
TAHNX
MITCH
Old June 15th, 2016, 03:10 PM
Rupp's Avatar
Rupp Rupp is online now
Try browsing away from the HS3 web interface and then back and the plugin list should try to refresh.
-Rupp
Old June 15th, 2016, 04:05 PM
still no go
that did not work and I stopped hs3 and restarted it got this message
6/15/2016 4:16:31 PM ~!~BLiTunes Error~!~Caught this exception setting up iTunes - Retrieving the COM class factory for component with CLSID {DC0C2640-1415-4644-875C-6F4D769839BA} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
6/15/2016 4:16:31 PM ~!~Error~!~Initializing plug-in(1): BLiTunes Instance::There is an issue with iTunes so the plug-in cannot run!!Startup Complete, 3 errors detected, check the log for more information.
Old June 15th, 2016, 04:08 PM
Blade's Avatar
Blade Blade is offline
What version of the plugin?
What version of iTunes installed?
Cheers,
Bob
Old June 15th, 2016, 04:18 PM
got it
ITunes was not on this computer it was on another computer on the network. I expected it to see it there. I just installed iTunes on the same computer and it is now initialized.
The end goal is to have it play music on other computers that are connected to stereo equipment and controlled by hstouch on ipads etc. HS3 is on a VM in a server rack.
Am I asking to much or is this possible ?
BTW it does not have to be iTunes I have all the music files on network accessible hard drives
THANX
MITCH
Old June 16th, 2016, 05:30 AM
Blade's Avatar
It only works with iTunes installed on the machine where the plugin is running
Install Issue skybolt WeatherXML 15 April 13th, 2009 03:50 PM
Initial setup problems on re-install toddgraham MCS Temperature 2 September 9th, 2008 01:35 PM
Trouble with initial install of Insteon Icon Siwtches... kevinsul General Home Automation Hardware Discussion 1 April 8th, 2006 05:41 PM
re-install issue pete17c MCS Temperature 3 April 6th, 2005 06:18 PM
