Sorry guys but I'm tearing my hair out over this one!
I had an old Aeon stick that works fine but wanted to upgrade it to a Znet.
Followed all the instructions and all I get all the time is this on the Znet interface:
The Home ID being just 00000000 (Not Valid)
I've removed it, deleted it, restarted it, everything I can find on the boards and it simply refuses to change.
The log shows:
For the life of me I can't work out what's wrong or what to do to make it work.
I even deleted the other two Zwave interfaces totally, restarted, and all that as well to no avail.
Please, any help would be greatly appreciated as right now I've got no Zwave at all.
K.
The log shows:
Jan-02 2:41:58 PM Z-Wave Z-Net: Getting node information from controller...
Jan-02 2:41:58 PM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.2.130, connected to interface ok.
Jan-02 2:41:58 PM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.2.130...
Jan-02 2:41:56 PM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jan-02 2:41:55 PM Z-Wave Z-Net: Getting node information from controller...
Jan-02 2:41:55 PM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.2.130, connected to interface ok.
Jan-02 2:41:55 PM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.2.130...
Jan-02 2:41:54 PM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.2.130, connected to interface ok.
Jan-02 2:41:54 PM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.2.130...
Jan-02 2:41:54 PM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jan-02 2:41:54 PM Z-Wave Z-Net: Getting node information from controller...
Jan-02 2:41:54 PM Z-Wave Error Z-Net: Exception transmitting to IP 192.168.2.130: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
Jan-02 2:41:53 PM Z-Wave Z-Net: Getting node information from controller...
Jan-02 2:41:53 PM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
K.
