This is the Beta release of the Life360 Plugin. Testers ONLY as this may still have some bugs. Do not use for critical/emergency/life endangering uses.
Features:
Supported Platforms
Things To Do:
Screenshot:
Issues/Suggestions:
Please send me PM or post in this thread any issues you encounter.
Install:
Download the attached Zip file and updater_override.txt file.
Copy the updater_override.txt file to your HS3 root directory
Windows: C:\Program Files (x86)\HomeSeer HS3
Linux: Varies by install decisions
Copy the Plugin Zip file to your HS3 root directory/Updates3/Zips
Windows: C:\Program Files (x86)\HomeSeer HS3\Updates3\Zips
Do NOT extract the Zip file.
From the Web Interface Select:
PLUG-INS -> Manage
Click -> Update Listing
After the Update progress bar comletes
Click the Yellow Arrow next to "Additional Interfaces"
At the bottom will be "Beta" click the arrow to expand
Click the checkbox to install
Look up about to Pending Updates/Installs
Click Download and Install
Once Installed refresh the Plug Ins -> Manage Page
Click Plug-Ins and there will be a new item for Life360. Select Config
Enter your Life360 Username and Password
CHECK the Enable checkbox. This Enables the update interval
Choose a room/location for new devices or leave the default as Life360
Default refresh timer is 1 Minute. Adjust to suit your preference of updates.
Click the "Create Devices Button"
Now the Root devices for Life360 Circle Members is going to be created in the background. Select any additional features you want to enable. Place/Location is enabled by default.
Help has been added into the configuration page. Please review and provide feedback/questions. This needs to be updated based on a lot of recent updates.
The Create Devices button is also used to add new Life360 Circle members if added after the plugin is installed.
All devices should be created and the update interval is now active. If you add new people to your Life360 circle after the plugin has been installed go back to the configuration page and click Create Devices. This will create devices for new people or if devices are removed you can re-create them.
Places are now synchronized with Life360. If however they do become out of sync you can click the Update Places button to initiate a sync.
Latest Fixes
New Features
0.0.2.59 Updates
Note: There are breaking changes with the new Places update system. To ensure things work I highly recommend a full removal of the plugin and fresh install. To remove disable the plugin. Delete ALL devices and delete the config/life360 directory. Then copy the contents of the zip file into your HS3 directory.
Update: 0.0.2.60
Update: 0.0.2.78
Update: 0.0.2.79
FIXED a bone head mistake of the default connection. Should now work. Anyone that tried 0.0.2.78 and it would not initialize this should be fixed.
Update: 0.0.2.93
FIXED - Plugin Configuration not saving properly
FIXED - Places Configuration not being saved and reused on restart
Removed unnecessary logging
Update: 0.0.2.98
Added Lat/Long Child devices
Notes for 0.0.2.98: This release requires a delete and re-create of devices as I have not had time to figured out yet how to add a child to a root that already exists. There is a new image in the zip file to go along with the Lat/Long that should be copied to your images directory. The only thing new is the LAT/LONG if that's not important to you then no update is needed.
Update: 0.0.3.1
I screwed up with the Plugin and had it returning True for device configs. This resulted in a tab being created for new virtual devices. This has been fixed....I think
Update: 0.0.3.64
This update will require a full install. Delete existing devices and copy the whole package into your HS3 root directory. New devices of the lat/long and google map location will be added when devices are created during setup.
-Added check for Long/Lat format
-Added Google Map Child device with link that opens in a new window
-Added a Null/Empty check for Wifi State. Apparently sometimes it will return empty
Update: 0.0.3.76
This update is a standard package. Please the zip file in your hs3_root/Updates3/Zips directory and the update_overider.txt in the hs3 root directory. From plugin manager you should see Life360 showing an update if not click on the update option button to load the new updater file. Stop Life360 and select update. If this is a new install expand the sources and in the Beta section is where Life360 will be listed. This is in preparation for release to the HS3 Plugin Store.
- Places and Devices updated on each update cycle
- Fixed Alternative places with "Home" in their name ie Home Depot showing icon for home
- Devices now optional per configuration settings
- Child devices created/deleted based upon options in configuration
Update: 0.0.3.82
- Added "Is Driving" device. It's available in the configuration. It is supposed to work with phone with "Drive Mode". YMMV
- By default only "Location/Places" is active on initial install. Select additional devices you want from configuration
- If you have an older release prior to packaging a re-install may be necessary
I think this PI is now feature complete with all current Life360 "abilities" and with the capability of now adding/removing devices as needed without requiring full re-installs. Please test and provide feedback as I think this is ready for Beta release in the HS Store.
Remember to download BOTH files.
Latest Screenshot:
BETA Release: 0.1.4.53
- I've been busy hence the major increase in version numbers.
- Some code clean-up and cleaning
-Major FeatureSynchronizing Life360 Places with the Plugin. New Added are automatically added to devices and NOW Deleted Places from Life360 are removed from devices. The Places functionality is now complete. I think...maybe
NOTICE FOR EXISTING USERS
Latest version requires a DELETE and Re-Create of Member devices as the devices have been changed to use the Sync feature of Life360 Places.
- Generally speaking only a delete/re-create of the Location devices should be needed. But to be sure I say delete them all and re-create them all until.
Latest release is available from the HS3 Updater.
Features:
- Creates Root Device for each Circle Member
- Creates Child Devices for each element
- Elements: Life360 Places, Unknown Places, Latitude, Longitude, In Transit, Speed, Wifi State, Battery Level, Battery Charging, Sharing Location
- Location will show Alternate Life360 Places when Away or Address if the Place is not known
- Life360 Places are synchronized from Life360 and used for Location Status and Events
- All devices have status/value pairs and can be used for events
- Live Google Map current location
- Link to Google Map (Less resource intensive)
- Element devices created/deleted by plugin configuration page
- All Elements are optional
Supported Platforms
- Windows
- Linux
Things To Do:
- Multiple Circles are NOT supported currently
- Removing of Life360 People does not remove their devices.
- Probably bug fixes
Screenshot:
Issues/Suggestions:
Install:
PLUG-INS -> Manage
Latest Fixes
- Added a default username/password instead of blank fields.
- Enhanced connection to Life360 - more error checking
- Added error handling for failed login. This was causing plugin crashing.
- Added more Debug logging
- Updated Configuration page information
- Adjusted speed back to just single integer that is displayed and not double decimals. The back end is now correctly handling the string to decimal conversion and rounding to nearest single integer. Recreation of devices is not necessary, but for testing you may want to delete and recreate devices
- Changed to update "Last Change" for Display String updates
New Features
- Supports Life360 Places for events. This requires a new install or re-creation of devices as it needs to update the value/status pairs for each location device. The Places are synced and stored in a file to persist across service restarts. There is an "Update Places" button which will update the configuration file but it currently does NOT update the devices. Still to come
- Adding of new members is as simple as clicking the "Create Devices" new or missing members will be created
- Lots of logging added
- Config page updated with some help info, more to come and styling
0.0.2.59 Updates
- Completely redid the Places support and Updating of Life360 places. Now everything is updating correctly and stored in a file in the config directory making it persist a reload of the plugin. There was an error in processing of the file that needed to be worked out. This should be resolved now.
- Logging has been reduced to 1 entry per update interval. If you update every minute you will get 1 log entry every minute. All other logging is an Error or in Debug mode only.
- All Locations/Places EXCEPT for the Away state are not pulled directly from Life360. So if you have Home setup in Life360 that is what it will be called in HS3. If you have it named "Domicile" in Life360 that is what it will be in HS3
Update: 0.0.2.60
- Updated paths to be Linux friendly
Update: 0.0.2.78
- Fixed a but running on Linux. Places were not created correctly due to a type cast problem. This was not an issue on Windows, however I did find it on Linux after moving my system to Linux. This was a hard one to find as it wasn't a problem on Windows but it threw an exception on Linux. --fixed
- Updated default altlocation.png again noticed it on Linux due to case sensitivity. --fixed
Update: 0.0.2.79
Update: 0.0.2.93
Update: 0.0.2.98
Update: 0.0.3.1
Update: 0.0.3.64
Update: 0.0.3.76
Update: 0.0.3.82
Latest Screenshot:
