Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion > RFXCOM Plug-In (3P)
RFXCOM Plug-In (3P) Discussion area for the RFXCOM 3rd party plug-in.
Old November 14th, 2017, 09:39 PM
GadgetBoySI's Avatar
GadgetBoySI GadgetBoySI is offline
Seer Deluxe
Starting over?
I have the RFXrec433 and the RFXCOM Plug in. Over the years, I've added a number of temp and weather sensors and I think I have may have a bad sensor and/or mismapped inputs. I'd like to just start over from scratch and re-add the sensors back into Homeseer.
Is it as easy as deleting all the devices and then uninstalling and reinstalling the plugin?
Jim
LazyAutomation
www.lazyautomation.com
la·zy [ley-zee] - Resistant to work or exertion; disposed to idleness.
au·to·ma·tion [aw-tuh-mey-shuh n] - The automatic operation or control of equipment, a process, or a system.
HS3Pro / HSTouch / JRMC 19 / Gizmo / M-Audio Delta 410 / 5 Zone Whole House Audio / UPB / ZWave / RFXCOM / Windows 7 HTPC / Ceton InfiniTV w/Xbox Extenders / W800
Old November 15th, 2017, 05:47 AM
b_weijenberg b_weijenberg is offline
OverSeer
A delete of the devices will be enough, no need to reinstall the plug-in.
Old November 15th, 2017, 06:47 AM
Seer Deluxe
Quote:
Even better! Thanks!
Old February 11th, 2018, 12:26 PM
Seer Deluxe
I deleted all temperature and weather devices and re-sync'd them with the plug-in and everything is working great - for that stuff.
I'm having issues pairing X10 security devices (both motion and DS10) and X10 motion sensors (such as the old Hawk devices).
For the X10 security sensors I'm going to RFXCOM>SECURITY SENSORS and the only item available to add is a "Virtual Security Sensor" after triggering any of my modules.
For the X10 motion sensors, I have the motion sensor set to A1, and I set up a device with that code in the device setup, and I am not seeing HS receive a signal whatsoever in the log.
Any idea on where to start?
Jim
Old February 12th, 2018, 09:21 AM
OverSeer
US X10 operates at 310MHz and is not received by the 433.92MHz RFXrec433
Old February 13th, 2018, 06:35 AM
Seer Deluxe
Really? I could have sworn I was using X10 with this previously - that would only apply to devices and not X10 security sensors, correct?
I have an old W800 laying around. I believe this plugin supports that hardware? Perhaps time to dust that off...
Old February 13th, 2018, 07:59 AM
langenet's Avatar
langenet langenet is offline
OverSeer
Yes the plugin supports the W800. I still use it to support DS10 security devices and a couple of X-10 motion detectors.
Robert
HS3PRO 3.0.0.435 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dot, WS+, WD+ ... on and on.
HTML code is On
Starting over; which way to go? DotCom Editor HomeSeer General Discussion Area 12 February 6th, 2012 08:44 AM
Starting over scotthpdx Security System Discussion 2 March 6th, 2009 08:45 PM
Starting over Bill Brower HomeSeer Z-Wave Plug-in 5 February 8th, 2009 11:39 AM
IR starting over. How-to? Best way? Stef ADIOcelot 2 July 11th, 2007 07:55 AM
So if I am just starting out djnrook HomeSeer Z-Wave Plug-in 6 January 16th, 2004 05:16 PM
