Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > Nest Devices (3P)
Nest Devices (3P) Discussions related to the Nest devices plugin for HS3 developed by SPUD.
  #41
Old February 9th, 2018, 05:28 PM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
A user sent me their HS3 folder and I am running it here on an SEL and I see the issue. Difficult to debug but I am working on it. So far a mystery. It appears that something in MONO is using the CPU as none of the HS threads show as active when the CPU is high. Will report when I know more.
Quote:
Originally Posted by jnpoyser View Post
Same symptoms here, and similar setup - Linux / nest / zwave. System locking up after a few hours with high cpu usage. Just disabled nest plugin and restarted, let’s see...
  #42
Old February 13th, 2018, 10:26 AM
rjh's Avatar
rjh rjh is offline
Might have a fix for this, or at least my test system has run the longest it has ever run. If you are seeing this issue update to HS3 build 415 which is posted here:
https://forums.homeseer.com/showthread.php?t=181241
  #43
Old February 14th, 2018, 06:32 PM
mloebl's Avatar
mloebl mloebl is offline
Seer Master
So far after 24 hours this seems to be working well for me. Thanks for the help!
  #44
Old February 25th, 2018, 02:25 PM
jnpoyser jnpoyser is offline
Seer
I’ve been running the beta for 3 days now with no hanging. Thanks all.
  #45
Old March 3rd, 2018, 11:29 AM
smashburn smashburn is offline
Seer
This may be a dumb question but I dowloaded build 415. unzipped the file and clicked on autostart. Nothing happened. Still with old build. What am I doing wrong?
  #46
Old March 5th, 2018, 11:26 AM
rjh's Avatar
rjh rjh is offline
I assume you are using Linux? Are you using your own Linux build?
If you are on one of controllers, you can update from Setup.
If you are on your own controller then make sure you untar the file to /usr/local/HomeSeer.
Quote:
HTML code is Off
The Crashing of HS3 .368 wadesready HS3 / HS3PRO Discussion 0 November 14th, 2017 06:18 AM
HELP zwave network crashing - Solution! collegeboyslive HomeSeer General Discussion Area 20 December 24th, 2015 10:38 AM
app keeps crashing completelyhis Script Connector 2 February 9th, 2009 09:13 AM
HS Crashing MalcolmS HomeSeer Z-Wave Plug-in 0 January 11th, 2006 07:21 PM
