A lot of us are often looking for a good 12 volt PS to power many other auxiliary glue devices. One fellow mentioned taking 12 V off the PC and bringing it out.
I just bought a 500 Watt Ultra ATX power supply from directron.com for 79.95 less $30 rebate or $49.95. This supply comes with seperate cables that you plug into the supply so you only have cables you need. The supply is esthetically pleasing, has two 80mm fans and is very very quiet. It will deliver 34 amps at +12 volts but the total output of all voltages may not exceed 480 watts. Output voltages have overvoltage and overcurrent protection.
I modified the unit as follows:
Took off the cover (4 screws)
Drilled 4 holes into what I call the back, but is actually a side. This will allow me to mount it on the plywood wall and then put back on the cover.
Cut into the ATX connector lines to get at the wires for Pin 14 (green) and common (ground, any black wire). I drilled a hole in the cover and mounted a small toggle switch and connected it to the green and black wires. This is the power on off switch for the supply. I could have connected the ATX power cord and modded it, but I wanted less cords coming off the PS. The "12V" cord which normally is used for Hard Drives supplies 12V and 5V (2 blacks a yellow(12) and a red(5)). They actually supply a mess of cables to handle any configuration.
This unit is ATX specific providing +/- 12V, +/- 5V and +3.3V
When it is all mounted and connected to the Altronix Fuse block I will start taking pics and post them.
