This plugin is designed to interface HomeSeer with IFTTT ("If This Then That")
Please report any bug.
Please read the User Guide before installing.
Installation:
Changes to v3.0.1.3
- Do not overwrite existing dropbox files. This was preventing IFTTT applets to run in some cases.
Changes to v3.0.1.2
- Updated Dropbox library to version 4.3.0
Changes to v3.0.1.1
- Fixed problem with additional trailing slash or missing starting flash for IFTTT action folder
Changes to v3.0.1.0
WARNING: The Dropbox integration has changed, with this version you need to reauthorize your account
- Upgraded to Dropbox API v2
- Added the "RunIFTTTAction" scripting function
Changes to v3.0.0.11:
- Log the "Invalid JSON string" error at the Debug level as it is harmless and appears frequently.
Changes to v3.0.0.10:
- IFTTT triggers now respect event conditions
Changes to v3.0.0.9:
- Added timeout for longpoll http request so that the plugin doesn't get stuck when connection drops
Changes to v3.0.0.6:
- Fixed authorization process
Changes to v3.0.0.5:
- Added possibility to specify a file name for IFTTT actions
Changes to v3.0.0.4:
- Various fixes
Changes to v3.0.0.3:
- Better handling of network errors
Changes to v3.0.0.2:
- Implemented long polling to replace standard polling mechanism
Changes to v3.0.0.1:
- Fixed issue with https request on Linux
Installation:
- download the zip attached to this post and save it in the HS3 application folder in /updates3/zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the IFTTT line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
Changes to v3.0.1.3
Changes to v3.0.1.2
Changes to v3.0.1.1
Changes to v3.0.1.0
- Various fixes
