Help with setup
    Help with setup
    I struggled getting Mono installed on the Pi. My Linux skills are cut & paste :-)
    It looks like a lot of it worked. But I'm totally lost!
    May-03 12:50:04 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:49:59 PM Starting Plug-In Plugin RaspberryIO started successfully in 57 milliseconds May-03 12:49:59 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:49:59 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:49:59 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50734 May-03 12:49:59 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:49:59 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:49:56 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:49:56 PM RaspberryIO INFO Shutting Down plug-in May-03 12:49:56 PM RaspberryIO INFO Shutting Down plug-in May-03 12:49:56 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 63 milliseconds May-03 12:49:56 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:49:56 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:49:56 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:49:56 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60954 May-03 12:49:32 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:49:27 PM Starting Plug-In Plugin RaspberryIO started successfully in 52 milliseconds May-03 12:49:27 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:49:27 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:49:27 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50697 May-03 12:49:27 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:49:27 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:49:24 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:49:24 PM RaspberryIO INFO Shutting Down plug-in May-03 12:49:24 PM RaspberryIO INFO Shutting Down plug-in May-03 12:49:24 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 95 milliseconds May-03 12:49:24 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:49:24 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:49:24 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:49:23 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60950 May-03 12:49:00 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:48:55 PM Starting Plug-In Plugin RaspberryIO started successfully in 52 milliseconds May-03 12:48:55 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:48:55 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:48:54 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50649 May-03 12:48:54 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:48:54 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:48:51 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:48:51 PM RaspberryIO INFO Shutting Down plug-in May-03 12:48:51 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 53 milliseconds May-03 12:48:51 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:48:51 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:48:51 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:48:51 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60946 May-03 12:48:27 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:48:22 PM Starting Plug-In Plugin RaspberryIO started successfully in 50 milliseconds May-03 12:48:22 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:48:22 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:48:22 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50607 May-03 12:48:22 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:48:22 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:48:19 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:48:19 PM RaspberryIO INFO Shutting Down plug-in May-03 12:48:19 PM RaspberryIO INFO Shutting Down plug-in May-03 12:48:19 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 46 milliseconds May-03 12:48:19 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:48:19 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:48:19 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:48:19 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60942 May-03 12:47:55 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:47:50 PM Starting Plug-In Plugin RaspberryIO started successfully in 50 milliseconds May-03 12:47:50 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:47:50 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:47:50 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50570 May-03 12:47:50 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:47:50 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:47:47 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:47:47 PM RaspberryIO INFO Shutting Down plug-in May-03 12:47:47 PM RaspberryIO INFO Shutting Down plug-in May-03 12:47:47 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 46 milliseconds May-03 12:47:47 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:47:47 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:47:47 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:47:47 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60938 May-03 12:47:23 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:47:18 PM Starting Plug-In Plugin RaspberryIO started successfully in 53 milliseconds May-03 12:47:18 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:47:18 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:47:18 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50528 May-03 12:47:18 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:47:18 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:47:14 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:47:14 PM RaspberryIO INFO Shutting Down plug-in May-03 12:47:14 PM RaspberryIO INFO Shutting Down plug-in May-03 12:47:14 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 52 milliseconds May-03 12:47:14 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:47:14 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:47:14 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:47:14 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60934 May-03 12:46:51 PM HSTouch Server Debug 12:46:51:4578 ~ Value change ref:27 Address:CC4559FE-002 NewVal: 99OldVal: 99 May-03 12:46:51 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:46:46 PM Starting Plug-In Plugin RaspberryIO started successfully in 48 milliseconds May-03 12:46:46 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:46:46 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:46:46 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50488 May-03 12:46:45 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:46:45 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:46:42 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:46:42 PM RaspberryIO INFO Shutting Down plug-in May-03 12:46:42 PM RaspberryIO INFO Shutting Down plug-in May-03 12:46:42 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 45 milliseconds May-03 12:46:42 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:46:42 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:46:42 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:46:42 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60930 May-03 12:46:18 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:46:13 PM Starting Plug-In Plugin RaspberryIO started successfully in 49 milliseconds May-03 12:46:13 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:46:13 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:46:13 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50453 May-03 12:46:13 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:46:13 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:46:10 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:46:10 PM RaspberryIO INFO Shutting Down plug-in May-03 12:46:10 PM RaspberryIO INFO Shutting Down plug-in May-03 12:46:10 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 58 milliseconds May-03 12:46:10 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:46:10 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:46:10 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:46:10 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60926 May-03 12:45:46 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:45:41 PM Starting Plug-In Plugin RaspberryIO started successfully in 50 milliseconds May-03 12:45:41 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:45:41 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:45:41 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50418 May-03 12:45:41 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:45:41 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:45:38 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:45:38 PM RaspberryIO INFO Shutting Down plug-in May-03 12:45:38 PM RaspberryIO INFO Shutting Down plug-in May-03 12:45:38 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 44 milliseconds May-03 12:45:38 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:45:38 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:45:38 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:45:38 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60922 May-03 12:45:14 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:45:09 PM Starting Plug-In Plugin RaspberryIO started successfully in 67 milliseconds May-03 12:45:09 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:45:09 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:45:09 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50375 May-03 12:45:09 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:45:09 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:45:06 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:45:06 PM RaspberryIO INFO Shutting Down plug-in May-03 12:45:06 PM RaspberryIO INFO Shutting Down plug-in May-03 12:45:06 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 61 milliseconds May-03 12:45:06 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:45:05 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:45:05 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:45:05 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60918 May-03 12:44:42 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:44:37 PM Starting Plug-In Plugin RaspberryIO started successfully in 48 milliseconds May-03 12:44:37 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:44:37 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:44:37 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50339 May-03 12:44:36 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:44:36 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:44:33 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:44:33 PM RaspberryIO INFO Shutting Down plug-in May-03 12:44:33 PM RaspberryIO INFO Shutting Down plug-in May-03 12:44:33 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 69 milliseconds May-03 12:44:33 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:44:33 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:44:33 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:44:33 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60914 May-03 12:44:10 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:44:05 PM Starting Plug-In Plugin RaspberryIO started successfully in 168 milliseconds May-03 12:44:05 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:44:05 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:44:05 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50304 May-03 12:44:04 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:44:04 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:44:01 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:44:01 PM RaspberryIO INFO Shutting Down plug-in May-03 12:44:01 PM RaspberryIO INFO Shutting Down plug-in May-03 12:44:01 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 56 milliseconds May-03 12:44:01 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:44:01 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:44:01 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:44:01 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60910 May-03 12:43:38 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:43:33 PM Starting Plug-In Plugin RaspberryIO started successfully in 50 milliseconds May-03 12:43:32 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:43:32 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:43:32 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50253 May-03 12:43:32 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:43:32 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:43:29 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:43:29 PM RaspberryIO INFO Shutting Down plug-in May-03 12:43:29 PM RaspberryIO INFO Shutting Down plug-in May-03 12:43:29 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 60 milliseconds May-03 12:43:29 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:43:29 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:43:29 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:43:29 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60906 May-03 12:43:05 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:43:00 PM Starting Plug-In Plugin RaspberryIO started successfully in 71 milliseconds May-03 12:43:00 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:43:00 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:43:00 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50204 May-03 12:43:00 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:43:00 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:42:57 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:42:57 PM RaspberryIO INFO Shutting Down plug-in May-03 12:42:57 PM RaspberryIO INFO Shutting Down plug-in May-03 12:42:57 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 61 milliseconds May-03 12:42:57 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:42:57 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:42:57 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:42:57 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60902 May-03 12:42:33 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:42:28 PM Starting Plug-In Plugin RaspberryIO started successfully in 63 milliseconds May-03 12:42:28 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:42:28 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:42:28 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:50047 May-03 12:42:28 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:42:28 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:42:25 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:42:25 PM RaspberryIO INFO Shutting Down plug-in May-03 12:42:25 PM RaspberryIO INFO Shutting Down plug-in May-03 12:42:25 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 56 milliseconds May-03 12:42:25 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:42:25 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:42:25 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:42:25 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60898 May-03 12:42:20 PM Z-Wave Starting Z-Wave Polling for Network CC4559FE... May-03 12:42:01 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:42:00 PM Warning A database 'save' was called less than 5 minutes after the system was started - this is being ignored or re-queued to promote database integrity. May-03 12:41:56 PM Starting Plug-In Plugin RaspberryIO started successfully in 59 milliseconds May-03 12:41:56 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:41:56 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:41:56 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:127.0.0.1:49989 May-03 12:41:56 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:41:56 PM Warning I/O interface RaspberryIO is down, executable is not running, restarting ... May-03 12:41:55 PM Z-Wave ************************************************************ ******************* May-03 12:41:55 PM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized. May-03 12:41:55 PM Z-Wave ************************************************************ ******************* May-03 12:41:53 PM RaspberryIO ERROR System is not a Raspberry Pi May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: ............................................................ .......... May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: .............................. FINISHED .............................. May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: ............................................................ .......... May-03 12:41:53 PM Z-Wave Z-WaveSmartStick is the SIS for the network. May-03 12:41:53 PM Z-Wave Z-WaveSmartStick There is a SUC/SIS in the network. May-03 12:41:53 PM Z-Wave Z-WaveSmartStick Controller is static lib. May-03 12:41:53 PM Z-Wave Z-WaveSmartStick Controller chip type is ZW050x. May-03 12:41:53 PM Z-Wave The interface's security support has been set. May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: Found 4 Z-Wave nodes in interface node ID 1 (Z-WaveSmartStick) May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: Z-Wave interface node ID: 1, Home ID: CC4559FE May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: Z-Wave Serial API version: 5 May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: Z-Wave services for the SECURITY COMMAND CLASS were successfully started. May-03 12:41:53 PM Z-Wave Z-WaveSmartStick: Controller firmware version: 4.32 May-03 12:41:53 PM Info Plugin RaspberryIO with instance: TestRemote has disconnected May-03 12:41:53 PM RaspberryIO INFO Shutting Down plug-in May-03 12:41:53 PM RaspberryIO INFO Shutting Down plug-in May-03 12:41:52 PM Error Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 Time to load: 87 milliseconds May-03 12:41:52 PM RaspberryIO ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <6051eb39012e4822bf3daa2a5be39e54>:0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <6051eb39012e4822bf3daa2a5be39e54>:0 May-03 12:41:52 PM RaspberryIO INFO RaspberryIO version 3.0.0.12 May-03 12:41:52 PM Starting Plug-In Initializing plugin RaspberryIO ... May-03 12:41:52 PM Info Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.86.55:60894 May-03 12:41:52 PM TTS Speak ():Welcome to Home-Seer May-03 12:41:52 PM Speaker Speaker host added, Name: NUCServer Instance: Default IP address: 127.0.0.1
    on your RPi you need to install the mono-vbnc package
    sudo apt-get install mono-vbnc
    This error
    suggests that you have the plugin enabled on your windows HS3 machine. Disable it.
      Well Crap
      It works! Now I have to purchase the plug in.
      Thanks so much for the help and a terrific tool.
