Apple Homekit(Siri) integration with Homeseer
Documentation is missing on your site, so I don't know what to do
Edit: I've got it, I'll still have to execute the exe in the backgroundLast edited by michaeldecharon; January 14, 2016, 04:52 PM.
Originally posted by michaeldecharon View PostDocumentation is missing on your site, so I don't know what to do
Edit: I've got it, I'll still have to execute the exe in the backgroundRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Hi rien i checked , The requested URL /HS3/JsonConfigForHomeKit3/HomeSeer Json Config for Homekit plug-in V3.0 documentation.pdf was not found on this server.
I think the file has spaces in the name
Verzonden vanaf mijn iPad met TapatalkPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
Perfecto
Originally posted by BIGMACK48 View PostI install your plugin and added the path for the configure file and hit save, but don't see the the main web page.
Thank you
GregRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by BIGMACK48 View PostI don,t see the HomeKit page where you
set advanced configuration options.
Greg
After you have installed the NodeJS based Homekit Bridge and installed en a
enabled the plugin, you simply edit any device and go to the JsonConfigForHomekit tab.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by stipus View PostYou are right: The Http shim is one way only whereas the HomeSeer platform is two-way.
- Http Shim: can only control a HomeSeer device from HomeKit
- HomeSeer platform for HomeBridge: can control a HomeSeer device, and get HomeSeer device status from any HomeKit enabled IOS app.
- HomeSeer plugin (not yet available): should also be able to send HomeKit events when a HomeSeer value changes. The HomeSeer platform cannot do this, unless I add a polling mechanism that gets HomeSeer device values every minute or so...
1. So, the HomeSeer platform can provide status when requested?
2. But, when using an IOS app, status won't be available automatically unless explicitly asked for?
3. Will a plugin be available that will handle event notifications of status changes?
4. Does the package that stipus provide contain both the homebridge software and HomeSeer platform in one package?
5. Does this package require that it run in Windows and in the same server as HS3? I have an old HomeTroller and was thinking of putting the homebridge software in an Ubuntu VM (or create a Windows VM and put HS3 and homebridge in it).
Thanks.
Originally posted by randman View PostI'm trying to catch up on this thread, but lots to read! Some questions:
Thanks.
Originally posted by Child_Roman View PostYesterday, i was looking for a good way to handle event notification to my iWatch(wanted too know if someone is at the frontdoor. This is easely possible with the app pushover and an node.js interface. It know gives me notifications with even different sounds(on iPhone). It also works on android and M$. If you want to know more just ask.
I would love to read more about it
Originally posted by Child_Roman View PostYesterday, i was looking for a good way to handle event notification to my iWatch(wanted too know if someone is at the frontdoor. This is easely possible with the app pushover and an node.js interface. It know gives me notifications with even different sounds(on iPhone). It also works on android and M$. If you want to know more just ask.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
