Originally posted by TeleFragger
View Post
Mission Critical Plug-ins - take #2
My "OTHER" vote is also for the TED plug-in. I am using two TED 5000 gateways for a total of 8 MTUs and, along with the jcaddx security plug-in that is "being worked on", the lack of a TED HS3 plug-in is keeping me from going completely to HS3. I believe the current HS2 TED plug-in only supports one MTU and so would request support for at least 4 MTUs and potentially the setup of multiple gateways each supporting up to 4 MTUs. I am not interested in throwing out the TEDs and starting over with something completely different just because it was chosen to be supported in HS3. I currently am running two VB scripts, one for each gateway, in HS2 that supports creating the devices for the MTU metrics in HS. I am looking at porting that to HS3 in case there is no support for an HS3 plug-in down the road.
Did you guys see this post from Bob on creating a TED plugin?
http://board.homeseer.com/showthread.php?t=169456
Would like to know if HSPhone will be able to support more than one W2C Unit for multi-line support.
Also, what is going on with the Media Center Plugin...
Without that, HS3 is not an upgrade path for the 4 customers I have left on HS.Transitioning to HS3Pro .298 - WinXPEmbedded
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
Originally posted by Dafunktyfunk View PostWould like to know if HSPhone will be able to support more than one W2C Unit for multi-line support.
That's a sorry excuse for not a developing wmc plugin . Facts are that lots of people already have wmc in use and truthfully there's not much wrong with it.
Even one of the devs on here volunteered his source code making your work as simple as porting from HS2 -->> HS3.
Just cause a manufacturer stops production of a product, doesn't means the customers must suspend or cease the use of what they already bought. If your mentality applied to automobiles, we sure would be in a big mess as a nation.HSPro: 3.0.0.194
PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
The Dev is Tom (Sage plugins) and you would need to contact him.
Here's the post of his offer. -->> http://board.homeseer.com/showpost.p...4&postcount=19
I'm just a user and not a Dev, so I can't help with any porting. But if there's any testing or other contributions needed that are within my limits, I'm all in to help push a product like this to HS3.HSPro: 3.0.0.194
Originally posted by CharlieWayne View PostThe Dev is Tom (Sage plugins) and you would need to contact him.
I'm just a user and not a Dev, so I can't help with any porting. But if there's any testing or other contributions needed that are within my limits, I'm all in to help push a product like this to HS3.Transitioning to HS3Pro .298 - WinXPEmbedded
I think your right about him being busy. Someone needed something from him before and it took a awhile for him to respond, but he did after a while.
Thanks for stepping out and making effort to port this plugin forward into HS3. I know there's some others that want it also.HSPro: 3.0.0.194
Originally posted by GregKing View PostThat and no UPB makes HS3 a non-starter for me.
I'm not using the Ocelot/Secu16 for anything else.
What's a good alternative to the Ocelot for IR?
(moderately priced and reliable)
There is a third party (3P) plugin for UBP available. For IR, I'd recommend the Global Cache line of products which are supported both by a HST and a 3P plugin and seem to have a large user base. The Ocelot plugin code was loaded onto Github (see http://board.homeseer.com/showthread.php?t=171429), so someone may pick it up and add the IR component.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
