@Moskus, does it work now?
Is DropBox trigger working for anyone in IFTTT?
Aha, THERE that damn button is. I thought it was up to each individual event/action to implement it...
Just ran, I'll report back in 15-20 minutes.
EDIT: That did the trick! Now it works!Last edited by Moskus; September 20, 2017, 02:47 AM.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
Having a similar problem with triggers not working (using Stringify, but also appears to not be working for IFTTT). Essentially, having an email trigger add a txt file into dropbox to activate a scene or device. The creation of the txt file appears to be working fine, but I am unable to get an event to activate. Manually moving a txt file into the folder in dropbox doesn't activate the event either. Attached is the debug info in the log and one of the events. Thoughts?
Jan-28 2:06:19 PM IFTTT DEBUG path/not_found/.. for /stringify/disarmed
Jan-28 2:06:18 PM IFTTT DEBUG path/not_found/ for /stringify/stay
Jan-28 2:06:17 PM IFTTT DEBUG path/not_found/. for /stringify/away
Originally posted by knaack View PostHaving a similar problem with triggers not working (using Stringify, but also appears to not be working for IFTTT). Essentially, having an email trigger add a txt file into dropbox to activate a scene or device. The creation of the txt file appears to be working fine, but I am unable to get an event to activate. Manually moving a txt file into the folder in dropbox doesn't activate the event either. Attached is the debug info in the log and one of the events. Thoughts?
I just tested this again on my system and it worked fine.
Originally posted by knaack View PostAttached. Only other thing I can think of that may be affecting it is that my dropbox folder location is on a different drive than default. Unless, of course, that I'm missing something easily fixable (which is entirely possible).
