Running HS3 on SEL with Z-Net version .368 on SEL. Changed network so IP changed. I updated IP address in Ra2 plug-in and all was working. I then updated to version .368, restarted my SEL and plug-in will not load. Tried to delete the plug-in and reinstall but still does not load. Keep getting the following messages in the log:
Mar-15 3:26:51 PM Error Initializing plug-in(2): LutronRA2 Instance::Object reference not set to an instance of an objectSTACK: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000] in :0
Mar-15 3:26:47 PM LutronRA2 Starting initializiation. Telnet
Mar-15 3:26:47 PM Starting Plug-In Initializing plugin LutronRA2 ...
Mar-15 3:26:21 PM Error Initializing plug-in(2): LutronRA2 Instance::Object reference not set to an instance of an objectSTACK: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000] in :0
Mar-15 3:26:17 PM LutronRA2 Starting initializiation. Telnet
Mar-15 3:26:17 PM Starting Plug-In Initializing plugin LutronRA2 ...
Mar-15 3:25:51 PM Error Initializing plug-in(2): LutronRA2 Instance::Object reference not set to an instance of an objectSTACK: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000] in :0
Mar-15 3:25:47 PM LutronRA2 Starting initializiation. Telnet
Any suggestions??
Any suggestions??
