I have started seeing this recently on startup of Homeseer:
Jun-27 19:41:17 Starting Plug-In Initializing plugin BLRadar ...
Jun-27 19:41:17 Error Initializing plug-in(2): BLRadar Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
Jun-27 19:41:06 Warning Attempt by plugin to register a duplicate link of blradar. Plugin: BLRadar Instance:
Jun-27 19:41:06 BLRadar start Checking devices owned by BLRadar
Jun-27 19:41:06 BLRadar start Loaded configuration successfully
Jun-27 19:41:05 BLRadar start BLRadar version is: 2.0.140.0
I don't get it everytime, but it does occur enough to be quite annoying. So far it has always only been on BLRadar for me I haven't seen it on any other plugin. I have tried to move the order of the plugins loading and put BLRadar first and while that seemed to help that time it sometimes still gets the error even when it is first in the load order. Noramlly stopping and starting the plugin doesn't work. Sometimes I can cycle Homeseer or I might have to reboot the computer to get it working again.
I did check for other posts about the problem and didn't see any for BLRadar, but saw a few instances on other plugins, but I haven't been able to find a permanent resolution.
Jeff
Jeff
