Inspired by this...
http://www.digi.com/wiki/developer/i...l_signal_lines
... I've been working on a plugin that can monitor the signal lines of a serial port.
My reason for starting this project was to provide accurate monitoring of my garage door which has a reed switch installed.
Using a Z-Wave or Insteon window/door sensor has worked fine for the most part but I wanted something more reliable (ie immune to batteries dying).
I didn't want to add the garage door as a zone to my alarm system to avoid the need for further alarm programming (managed system).
WHAT THE PLUGIN DOES
The plugin monitors the signal lines of a serial port (DSR / DCD / CTS) and then sets an associated Homeseer device to either on(100) or off(0).
A DB9 connector with 3 pairs of wires is connected to the serial port. When a pair is shorted the associated signal line is closed and the plugin updates the Homeseer device.
Each pair can be connected to anything that can short the connection. If you have voltage on the line then an optoisolator or relay can be added to avoid damaging the serial port.
Each serial port can handle 3 distinct dry contacts / Homeseer devices. I have tested with a Digi Edgeport and USB to Serial adapter cable. I've only tested it on the bench (no real cable length).
The plugin is in early development but if you want to have a play let me know.
Chris
Chris
