I have two receivers (e300 and 1912) set up through the plugin and I've noticed that that status for some of the devices seems to constantly update every 10-20 seconds. On one of the receivers, all devices work and update when changed except for mute, which is doing the constant updating, and on the other, it is zone two power, mute, and the inputs. Any idea what is causing this?
Statuses updating every 10-20 seconds
I need you to turn on debug logging in the plugin and capture the issues
Let me know the order in which you capture them and what you did
See this thread for the change to debug logging I have made and a fix you need to do
https://forums.homeseer.com/showthread.php?t=196104
Attach the BLDenon-Detailed.log file zipped once you have it.
Originally posted by Blade View PostI need you to turn on debug logging in the plugin and capture the issues
Attach the BLDenon-Detailed.log file zipped once you have it.Attached Files
While that did fix the issue with the frequent updating in the web interface, I noticed in logging HSTouch that it is apparently still sending updates to HSTouch clients every second. I am getting log entries such as this about every second:
Jun-25 1:56:01 PM HSTouch Server Debug 01:56:01:6631 ~ SendToClient iPhone:iPhone DataEVICECHANGE|84|0|0|/images/HomeSeer/status/off.gif|Not Muted[2]
Jun-25 1:56:01 PM HSTouch Server Debug 01:56:01:6615 ~ Value change ref:84 Address:BLDenon_002_Z2Mute NewVal: 0OldVal: 0
