Jon00 Device Viewer & Documenter
    Now Available!
    PLEASE NOTE: Requires Homeseer version 3.0.0.451 or higher
    This utility allows you display and search for settings/values for all virtual devices on your Homeseer setup.
    Device selection is made by a series of drop-down menus/filters including By Room, By Floor, By Device, By Other, By Name or By Reference number. There is also a search string text box where searched text is highlighted on the page for easy identification. The display can be further sorted with various ordering methods.
    Filtering 'By Other' includes:
    » Additional Display Data (True)
    » CAPI Control Data (True)
    » Confirm Voice Command (False)
    » Confirm Voice Command (True)
    » Invalid Device (True)
    » Hide Device From Mobile Views (False)
    » Hide Device From Mobile Views (True)
    » Hide Device From Views (False)
    » Hide Device From Views (True)
    » Include In Power Fail (False)
    » Include In Power Fail (True)
    » Is Dimmable (False)
    » Is Dimmable (True)
    » Is Light (False)
    » Is Light (True)
    » MyHS Device Change Notify (False)
    » MyHS Device Change Notify (True)
    » Linked Device (False)
    » Linked Device (True)
    » No Last Change Date/Time Update (False)
    » No Last Change Date/Time Update (True)
    » Do Not Log Commands (False)
    » Do Not Log Commands (True)
    » PED Named Data (False)
    » PED Named Data (True)
    » PED Unnamed Data (True)
    » Relationship Status Child (True)
    » Relationship Status Indeterminate (True)
    » Relationship Status Not Set (True)
    » Relationship Status Parent (True)
    » Relationship Status Standalone (True)
    » Script Button Data (False)
    » Script Button Data (True)
    » Supports Status (False)
    » Supports Status (True)
    » Use Pop-up Dialogue For Control (False)
    » Use Pop-up Dialogue for Control (True)
    » Usernote (False)
    » Usernote (True)
    » Voice Command (False)
    » Voice Command (True)
    » Voice Command Text (False)
    » Voice Command Text (True)
    » Voice Command (True) & Voice Command Text (False)
    » Voice Command (False) & Voice Command Text (True)
    » Voice Command (True) & Voice Command Text (True)
    » User Access by Any
    » User Access by <user 1>
    » User Access by <user 2> etc
    Devices are either shown in a list view (Basic, Normal or Advanced) or Device View (similar format to HS3 device management page) which shows the metrics similar to the basic mode list. There is also a control page to operate devices via device drop-down's
    Advanced mode provides the most detail about a device including Plugin Extra Data (PED) which some plugin authors store information not normally seen.
    Where available, the following metrics are displayed:
    General:
    » Name
    » Floor
    » Room
    » Last Change
    » Technology Address
    » Technology Code
    » Value
    » Status
    » String
    » Usernote
    » Invalid Device
    » Status Image File
    » String as HTML Code
    » Thumbnail Image File
    » Image File
    Configuration Settings:
    » Support Status (Boolean)
    » Is Dimmable (Boolean)
    » Is Light (Boolean)
    » Hide device from mobile views (Boolean)
    » Hide device from views (Boolean)
    » Voice Command (Boolean)
    » Include in power failure directory
    » Use pop-up dialog for control
    » User Access
    » Linked Device
    Advanced:
    » No Graphics Display
    » No Status Display
    » No Status Trigger
    » Attention Icon Text
    » Device Type (String)
    » Device Type Internal (API)
    » Device Type Internal (Type)
    » Device Type Internal (SubType)
    » Version
    » Interface Instance
    » Interface
    » Scale Display Text
    » Misc Settings
    » Relationship Status Value
    » Additional Display Data Count
    » Plugin Extra Data (PED) Named Count
    » Plugin Extra Data (PED) Named Data
    » Plugin Extra Data (PED) Unnamed Count
    » Plugin Extra Data (PED) Unnamed Data
    Status Text & Control
    » Status Pairs Protected (Boolean)
    » CAPI Control Count
    » CAPI Control Data (Label, Value, Control Use, Control Type, Control Flag, Row, Column, Colspan)
    » Script Button Count
    » Script Button Data (Label, Script file, Sub or Function, Parameters, Row, Column, Colspan)
    » Status Pair Count
    » Status Text (Single Value) - Basic (Status, Value, Status-Control, Control Use)
    » Status Text (Range) -Basic (Status, Value, Status-Control, Control Use
    » Status Text (Single Value) - Advanced (Status, Value, Status-Control, Control Use, Prefix, Suffix, Decimal Places, Offset, Additional Data (Boolean), Has Scale (Boolean), Include Values (Boolean), Button Image, Button Image Type, Zero Padding (Boolean), Status Graphic File)
    » Status Text (Range) - Advanced (Status, Value, Status-Control, Control Use, Range Start, Range Finish, Range Status Divisor, Prefix, Suffix, Decimal Places, Offset, Additional Data (Boolean), Has Scale (Boolean), Include Values (Boolean), Button Image, Button Image Type, Zero Padding (Boolean))
    Key:
    Shown in Basic Mode
    Additionally shown in Normal Mode
    Additionally shown in Advanced Mode
    Reports in text format are available for any filter combination which is available from the web page or triggered by an event.
    As always, you can download from my site (click on my banner below)
    Please post any comments here.
    The screen shots below show the outputs in Advanced and device view:
ID:	1238689Click image for larger version
ID:	1238690Click image for larger version
    Jon
    Very good! A view for devices like your view for events. This will be very good for drilling down through devices or creating a device listing report. Lots of selection filters as well.
      I've updated the first post with more information. Still making a few tweaks before I release.
      Jon
        Very nice! I can't wait, thanks Jon.
        Billy
          Hopefully in the next day or two. The only caveat is that you need to be running Homeseer version 3.0.0.451 or higher.
          You can prepare by downloading it now: https://homeseer.com/updates3/SetupHS3_3_0_0_451.msi
          Jon
            V1.0.1 (Release version) is now available from my site. Please note the Homeseer version requirement of 3.0.0.451 (see previous post for download link). At this time I believe this version is only available for Windows.
            I would appreciate your comments.
            Jon
              It works very well . I like how similar it is to your Event Viewer and Documenter script. In addition to being able to search devices using almost any criteria, I will use this like the Event Viewer and generate weekly reports of all Devices for reference should one go missing. I may also generate some more specific reports.
              I also appreciate the donation reminder on the documentation. It reminded me to thank you properly for all of your effort. Donation sent!
                Jon, I have looked on the board and cannot find a reference to HomeSeer 3.0.0.451, did I miss the release notes somewhere?
                Billy
                  It is the same as .449 except .450 corrected an error with the device class voice command and 451 added a new one: https://forums.homeseer.com/showpost...12&postcount=5
                  Jon
                    V1.0.2 is now available
                    Changes since V1.0.1:
                    Corrected error with Room/Location swapped in sort drop-down.
                    Added additional sort selection (device value & status - for Device View)
                    Added column sort to Device view display.
                    Jon
                      Another very useful utility, donation sent!
                      One minor suggestion would be to use the users configured labels for Location 1 and Location 2 rather than the default Floor and Room.
                      Steve
                        Thanks Steve.
                        Actually that feature was in the original version but I took it out as longer names were upsetting the table name widths (which are fixed) on the device view page.
                        Jon
                          I suppose you could truncate the names to a fixed length to avoid long name problems.
                          Steve
                            Excellent work Jon. Thanks for everything you do to make using HomeSeer easier and increase it's usefulness. Your latest work is nothing short of stellar.
                            Thanks again for all you do, it is appreciated. I made a small donation as thanks.
                            Billy
                              Many thanks Billy. Appreciate the compliments and donation. I've responded to your PM.
                              Jon
