All,
This is beta...I made a lot of underlying changes to correct the fanlinc linking issues. Please backup your hs database and insteon.ini
Known Issue
with HS3 .130, the refresh isn't working when the plugin is programming device/group changes. I'm working on this with HST.
New Actions
- Disable/enable the Interface - useful during a power outage to stop the Interface from logging errors. Create a event to Disable Interface when power is lost and another to Enable Interface when power is restored.
Fixes:
- Creating links to a Fanlinc will allow setting fan speed (off, low, med, high)
- Inlinelinc with sense On, Off btns restores
- On/Off devices will only get On/Off when creating links.
- Only dimmable devices should get On Level and Ramp Rate options when creating links.
- X10 dimming and status level tracking (3.0.5.1)
- HSTouch slider issue* (3.0.5.1)
- Device Sync issue with KPLs of type 0141 & 0142 (3.0.5.2)
- Potential fix for controlling X10 devices created with earlier versions (3.0.5.3)
- Fixed fanlinc fan control list (3.0.5.4)
- getrampratetext eror, outletlinc fix (3.0.5.6)
- date issue with non US installations (3.0.5.7 & 3.0.5.9)
- temperature issue with Energy Display (3.0.5.10)
*this is a one time fix
add the following to the insteon.ini [config] section
RecreateDevices=True
Changes:
- Set Filter button is no longer needed on Manage Device page. Just select your filter option and away you go.
- Username and password entry fields hidden until you enter the ip address and port, click Save and restart the plugin.
-Changes to the port settings on the config page should immediately restart the Interface. No need to restart HS. (3.0.5.1)
- added script function SetDeviceSyncLinkedDevices. this can be use to set the checkboxes via a script.
To execute use: hs.pluginfunction("Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"aa.bb.cc", true|false}) (3.0.5.6)
- Micro open/close Off control (3.0.5.8)
To Install:
1. Shutdown HS
2. Backup your current hs database and insteon.ini
3. Copy all the DLLs in the zip to the homeseer folder
4. Restart HS
This should be linux compatible but i didn't test it myself
Known Issues:
porttype=usb is not supported with Linux
small bug with Enable/Disable Interface that will generate errors
Known Issue
New Actions
Fixes:
Changes:
To Install:
1. Shutdown HS
4. Restart HS
Known Issues:
