I have a Linear wall switch and a Aeotec Micro Dimmer that are both not reacting at all. The wall switch still works when using it as a switch but all I have is the red "?" and the Aeotec is not connected to a switch, it's just managed with HS3 so I have some lights stuck on.
I would be really surprised that both units failed while I was away. Any suggestions?
Nov-19 10:24:24 Z-Wave Warning Failed to retrieve Z-Wave class information for node 20, device synchronization/creation will not continue for this node.
Nov-19 10:24:24 Z-Wave Cannot reach node 20, will not import any information about this node.
Nov-19 10:24:16 Z-Wave Checking if we can reach node 20
Nov-19 10:24:16 Z-Wave Getting class information for node 20...
Nov-19 10:24:15 Z-Wave Device synchronization needs to get Z-Wave class information for one node.
Nov-19 10:24:15 Z-Wave Syncing Z-Wave nodes with device list...
Nov-19 10:18:57 Warning Plugin Z-Wave is not responding but it is still running, not restarting yet.
Nov-19 10:18:52 Warning Unable to send event to plugin Z-Wave :Object reference not set to an instance of an object.
Nov-19 10:18:50 Error Calling ConfigDevice in plugin Z-Wave:Object reference not set to an instance of an object.
Nov-19 09:44:14 Z-Wave Warning Failed to retrieve Z-Wave class information for node 26, device synchronization/creation will not continue for this node.
