Aeotec ZW096 - maximum load in watts?
    How large a load can I plug into the ZW096...it's 15 amps does that mean 1650 watts?
    16 amp is around 3600 watt
    Sent fra min E6853 via Tapatalk
    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
      Not at 120 VAC...
      Cheers
      Al
        @120 VAC it is.....?
          Originally posted by sparkman View Post
          Not at 120 VAC...
          Cheers
          Al
          15 amps @ 110 = 1,800 Watts, or so it seems.
            Specs should be listed on the manual. The 1,800 watts is typically for a pure resistive load, like a light bulb (or a hair dryer). For non-resistive loads, like motors, most of these types of relays are limited to about 1/2 hp.
            That said, I have a wire-in appliance module of a different brand (Linear) that is limited to 1/2 hp, and have no problems operating it with a 1 hp misting system pump.
            In general, though, you shouldn't have a problem. 15 amps is a LOT of power.
