Hi Dirk, First of thank you for all the work that has gone into this plugin, its easily the most used one in my environment. Great job!
Is there a way to maybe populate a global variable with the last phrase spoken so we could have an option to repeat the last announcement if it was missed?
I see the announcements are stored in the C:\Program Files (x86)\HomeSeer HS3\html\Sonos\Announcements folder, so some scripting could be done to play the last group of wav files played for a linkgroup but modified dates of the files don't always make sense, (maybe it uses the original modified date of the wav file as your plugin isn't changing the file) I just wanted to check that something like this isn't already possible without another script.
Hope this makes sense.
Thank you,
Mike
Thank you,
Mike
