Originally posted by Camerun
View Post
iTunes DAAP plugin now works with HSTouch Media API, finally!
Originally posted by maui917 View PostI know this is an HS3Touch issue, but just bumping this thread again to see if you heard a response from Rich on the multiple sources issue.
http://board.homeseer.com/showthread...10#post1240710
Anything else I can do to get some attention on this?
Originally posted by maui917 View PostJust following up on this issue to see if you have had any response from Homeseer. I tried posting about it here but have had no response.
Originally posted by jpsavaria View PostHi,
The music browser works ok for pretty much everything (Artists, Songs, Genre, etc...) but but when it comes to Playlists, the list is empty even if I have multiple playlists in iTune.
It's working on the Web client, all the playlists are showing...
What versions of the following component are you running:
- HSTouch server plugin
- iOS HS3Touch app
- iTunes DAAP plugin
how many playlists do you have in iTunes?
does it work with the windows HSTouch client?
Originally posted by spud View Postsorry guys that it takes so long, I have just emailed Rich again.
I actually very recently decided to go the route you came from, i.e. make embedded HTML "frames" that you drop onto an HST screen that use Ajax to get dynamically updated, AND we could do anything we want in terms of the navigation versus what is hard-coded in the MusicAPI.
Dirk
Originally posted by spud View PostRich has fixed the multiple instances issues in HSTouch server version 3.0.0.103 available from the Beta section of the updater.
I have tested it with a windows HSTouch client and I can successfully browse the music library of 2 different iTunes instances.
Did he/you get anywhere with the issue of the playlist part of the MediaAPI not showing anything?
Dirk
Originally posted by tome10 View PostI try to put the mptest.xml into my skin, and I get a bunch of unknown object type errors in designer. What am I doing wrong?
If it is not working, it is easy to rerceate it from scratch:
Create a new ListBox and set its "status tracking" property to Music / Music selector.
Then create the buttons and labels and set their actions and status tracking with Music actions and associations (Current Track's Artist, etc...)
Well I installed the default player which seems to be working, but now I have a different issue. The plugin is not installing a speaker device for the tablet. Homeseer sees the speaker client, but the plugin is apparently not. I have reinstalled the plugin but did not fix the issue.
I went through the list you had of compatible components, but some of the revisions were not available.
Running:
iTunesDAAP 3.0.0.29
HSTouch Server 3.0.0.104
Client Android 1.0.136
