No Perl, I get it now.
Has anyone gotten Perl working in HS3?
I am trying to get perl working in HS3 and your post is a little cryptic.
Have you been told that perl will not work with HS3?
I am finally trying to move from HS2 and have a collection of perl scripts.
I was told back in 2012 that perl would be supported in HS3 on Windows:
http://board.homeseer.com/showthread.php?t=153646
Also, this thread:
http://forums.homeseer.com/showthread.php?t=166382
States that he had it working in HS3 about a year ago.
I am having no luck in my testing and just wanted to know if you have any information that perl support was removed.
I've never tried to use Perl w/ HS, but since you can run command line stuff via HS I would think you could use that to run your Perl scripts. Getting Perl to run on Windows or Linux is a separate issue, but once you can run your scripts via command line, you should be able to do the same via HS. I am running other command line stuff via HS right now.
Nevermind. I should've read the linked threads. I see you're looking for Perl/HS integration. I can't speak to that. Good luck!HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
