Here is the first release of the licensed plugin. Please post feedback and issues to this thread. Just wanted to thank Jono for his help testing the previous versions that lead to v1.5.
To Install:
1. Backup your current hs database and insteon.ini
2. Shutdown HS
3. Copy the hspi_insteon.dll to the homeseer folder
4. copy the insteon.lf to the homeseer\config (this will provide a 30-day trial)
New Features
- Self register new/unknown Insteon device types through the insteon.ini file
- Extra settings for V2 Motion Sensors (light level, battery level, etc)
- Poll the input sensor on a I/O Linc when in Momentary Mode
- Sync linked responder devices to help maintain status page (good for 3-way circuits)
- Insteon Action: Send Device Command - sends any custom Insteon cmd to a registered device
- Insteon Action: Light On at Ramp Rate - Turns a i2 light On/Off/Dim at a custom Ramp Rate regardless of device settings.
Device Support Added
- New ICON devices with latest firmware 39+
- GarageHawk garage door monitor
- Full support for the IO Linc
- Basic support for TimerLinc with Load Sensing
- Smarthome 240V N/C Relay
- Smarthome 240V N/O Relay
- New Switchlincs when released from Smarthome
Improvements
- Quicker processing of inbound and outbound insteon messages and commands
- Better support for switching a KPL from (6 to 8) or (8 to 6) button configuration without reregistering.
Fixes
- Use foreign characters in device names
- Register a 8 key Keypadlinc
- Delete links from groups
- Display issue on the Device Mapping page
Licenses are available in the Homeseer Store:
http://store.homeseer.com/store/PI-I...n-P948C94.aspx
To Install:
2. Shutdown HS
New Features
Improvements
Fixes
