I am trying to create a new event In the Action tab, I select "Insteon Actions" from the Add Action drop down. Then I select "Set Light Level at Ramp Rate" in the Select An Action drop-down. Under the Select Device drop down, only a subset of my Insteon devices are listed. For example, I have a dozen SwitchLinc V2 600W dimmers (firmware Version 38)... but only four of them are listed. Any ideas?
Insteon Actions Missing Devices
Originally posted by skimis View PostI am trying to create a new event In the Action tab, I select "Insteon Actions" from the Add Action drop down. Then I select "Set Light Level at Ramp Rate" in the Select An Action drop-down. Under the Select Device drop down, only a subset of my Insteon devices are listed. For example, I have a dozen SwitchLinc V2 600W dimmers (firmware Version 38)... but only four of them are listed. Any ideas?
to change this, shutdown hs, change one device and restart hs and see if it is added to the list.
if this does not fix the issue, i'll need to see a few examples from your ini for one that does display vs one that doesn't display in the list.Mark
HS3 Pro 4.2.19.5
Originally posted by skimis View PostThanks.... yep that did it. Is there something I did while registering those devices that caused them to be configured with Protocol=1? Can I change all my Insteon devices to Protocol=2, or is that only newer devices?
the best approach would be to shutdown hs and clear the protocol value of devices you suspect are wrong and then restart hs. then reread the settings and links of these these devices. this should reset the protocol valueMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postnot sure why the devices registered as i1. except for icon devices, switchlincs having a firmware of 30 or greater are generally i2.
Exactly how do you perform this task? I have several items listed as i1:
Switchlincs (both relay and dimmer)
keypadlincs
the new smaller lamp module
remotelinc
Some icons, but some are i2
Is this task to change the entry in the .ini file, or something otherwise?
John
keypadlincs
remotelinc
John
you need to shutdown hs first then make the changes then restart hs, then reread the links and settings for these devices. After you restart hs, you will see the Protocol value will change to Unknown on the Edit Device page so you know which devices to reread.Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostYes, you would be clearing the protocol values in the insteon.ini for device you suspect are wrong.
[Device 1]
DeviceID=0C.04.19
DeviceName=Water pump control (Insteon)
DeviceLocation=Garage
PollingInterval=5
DeviceType=0209
FirmwareVer=32
DatabaseDelta=11
LinksDownloaded=1
EEValues=
LastContact=3/28/2009 5:57:46 AM
NumLinks=9
Link 1=A2 01 0C A6 A1 FF 00 00 1
RecentDatabaseDelta=11
NoChannelSync=0
Link 2=A2 FE 0C A6 A1 FE 1F 00 2
Link 3=A2 16 0C A6 A1 FE 00 01 3
Link 4=A2 17 0C A6 A1 00 00 01 4
Link 5=A2 18 0C A6 A1 FE 00 01 5
Link 6=A2 19 0C A6 A1 FE 00 01 6
Link 7=A2 1D 0C A6 A1 FE 00 01 7
Link 8=A2 1E 0C A6 A1 FE 00 01 8
Link 9=A2 25 0C A6 A1 FE 00 01 9
What am I missing?
John
Yah I don't see it either. What about other devices?Mark
HS3 Pro 4.2.19.5
Are you sure you have the right insteon.ini file
Please post a screen shot of your register device page so i can see the protocol columnMark
HS3 Pro 4.2.19.5
