Proliphix tstats
    Proliphix tstats
    I'm trying out this plugin and have some issues with using this with 4 Proliphix tstats.
    Is there a way to create a name for the 1st instance of the plugin? It would help with identifying which tstat it is for when managing the plugin. It would also be great if the instance names are editable. It seems that once you give it a name, you can not change it. Also, can this name be displayed some place in the device view? It would also help when viewing all of the tstats to know which is which.
    The temp readings are all showing as Celsius, I checked the HS setup and it is set for Fahrenheit. Is there some way for me to change this?
    -Bob
