Constant error message in HS Log
    I have been having a problem for some time now which i never seem to get around to fixing.
    I have 7 Wemos (ESP8266) oards with DHT22 and Some with Relay's connecting to HS via the Arduino plugin.
    I get this message about once every 2 seconds or so..
    Arduino Plugin Error = Exception in RecievedAPIInput : Conversion from string "nan" to type 'Double' is not valid.
    Anyone have any Ideas?
    What is your Sketch sending as the plugin is not finding a number to be converted to the Value. NAN = Not a number. are you sending a string?
    Send me a debug log to look at if you can not sort this.
    Greig.
    Scripts =
    Various
      Code
        Arduino to Homeseer 3 Plugin written by Enigma Theatre.
         V1.0.0.134
       *******Do not Change any values below*******************
      int Output1 = 5;
      //int Output2 = 6;
      #define ISIP 1
      #define ESP8266 1
      #include <EEPROM.h>
      #include <ESP8266WiFi.h>
      #include <WiFiUdp.h>
      const byte BoardAdd = 7;
      byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x07};
      IPAddress ip(192, 168, 1, 37);     //IP entered in HS config.
      IPAddress gateway(192, 168, 1, 1);     //Gateway
      IPAddress subnet(255, 255, 255, 0);     //Gateway
      IPAddress HomeseerIP(192, 168, 1, 15); //Homeseer IP address
      IPAddress ServerIP(0,0,0,0);
      IPAddress LastRcvIP(0,0,0,0);
      char ssid[] = "myssid";  //  your network SSID (name)
      char pass[] = "mypassword";       // your network password
      const unsigned int localPort = 8080;      //port entered in HS config.
      byte EEpromVersion = EEPROM.read(250);
      //************Do not change anything in Here*****************
      int FromHS[10];                                          // *
      boolean IsConnected = false;                             // *
      char packetBuffer[UDP_TX_PACKET_MAX_SIZE];               // *
      WiFiUDP Udp;                                             // *
      const unsigned int ServerPort = 8888;                    // *
      void resetFunc() {   ESP.restart(); }
      #include <DHT.h>
      #define DHTPIN 2
      #define DHTTYPE DHT22
      #define Input8 D8
      DHT dht(DHTPIN, DHTTYPE);
      int SendDelay = 3000;
      long LastSend;
      int ami = 1034;
      void setup() {
        HSSetup();
        dht.begin();
        pinMode(Output1, OUTPUT);
        //pinMode(Output2, OUTPUT);
        pinMode(D8, INPUT);
      void loop() {
      IsUDP();
      if (IsConnected == true) {
         digitalWrite(Output1,FromHS[0]);
         //digitalWrite(Output2,FromHS[1]);
         if(millis() - LastSend > SendDelay){
      //****************Relay*****************
          ami = digitalRead(Input8);
          SendToHS(1,ami);
      //****************Temperature DHT*****************
          SendToHS(1,dht.readHumidity());
          SendToHS(2,dht.readTemperature());
           LastSend=millis();
      char* Version = "API1.0.0.136";
      byte Byte1,Byte2,Byte3;
      int Byte4,Byte5;
      void HSSetup() {
        EEPROM.begin(256);
        ServerIP = IPAddress(EEPROM.read(2),EEPROM.read(3),EEPROM.read(4),EEPROM.read(5));
          if (EEpromVersion!=22) {
          ServerIP=HomeseerIP;
          EEPROM.write(2,ServerIP[0]);
          EEPROM.write(3,ServerIP[1]);
          EEPROM.write(4,ServerIP[2]);
          EEPROM.write(5,ServerIP[3]);
          EEPROM.write(250,22); //Store the version where the eeprom data layout was last changed
          EEPROM.commit();
          EEpromVersion=22;
        Serial.begin(115200);
        // We start by connecting to a WiFi network
        WiFi.begin(ssid, pass);
        WiFi.config(ip, gateway, subnet);
        while (WiFi.status() != WL_CONNECTED) {
          delay(500);
      Udp.begin(localPort);
      Udp.setTimeout(0);
      delay(1000);
      SendConnect();
      void SendConnect()
      #if ISIP == 0
        Serial.print("Connect ");
        Serial.println(BoardAdd);
      #else
          Udp.beginPacket(ServerIP,ServerPort);  //First send a connect packet to the dynamic IP stored in eeprom
          Udp.print("Connect ");
          Udp.print(BoardAdd);
          Udp.endPacket();
          if (ServerIP!=HomeseerIP) {
            Udp.beginPacket(HomeseerIP,ServerPort);  //Then if the stored value doesn't match the pre-specified one, send a connect packet there also
            Udp.endPacket();
      #endif
      #if ISIP == 1
      void IsUDP(){
        int packetSize = Udp.parsePacket();
        if(packetSize)
          LastRcvIP = Udp.remoteIP();
          Byte1 =Udp.parseInt();
          Udp.read();
          Byte2 =Udp.read();
          Byte3 =Udp.parseInt();
          Byte4 =Udp.parseInt();
          Byte5 =Udp.parseInt();
          DataEvent();
      #else
      void serialEvent() {
        while (Serial.available() > 0) {
          delay(17);
          Byte1 = Serial.parseInt();
          Serial.read();
          Byte2 = Serial.read();
          Byte3 = Serial.parseInt();
          Byte4 = Serial.parseInt();
          Byte5 = Serial.parseInt();
          DataEvent();
      #endif
      Used Data Input Cases
      D Disconnect
      r reset
      K Keepalive
      O PinMode Output Set
      d Input debounce time set
      C Connect request
      c Connection established - report current status
      void DataEvent() {
      if (Byte1 == BoardAdd) {
          switch (Byte2) {
          case 'c':
            IsConnected = true;
      #if ISIP == 1
            if (LastRcvIP != ServerIP) {
              ServerIP=LastRcvIP;
              #ifdef ESP8266
              EEPROM.commit();
              #endif
      #endif
            break;
          case 'C':
      #if ISIP == 1
            Udp.beginPacket(LastRcvIP, ServerPort);
            Udp.print("Version ");
            Udp.print(" ");
            Udp.print(Version);
            Udp.println(" HS3");
            Udp.endPacket();
            delay(100);
            Udp.print("Connected ");
            Udp.println(BoardAdd);
            Udp.endPacket();
      #else
            Serial.print("Version ");
            Serial.print(BoardAdd);
            Serial.print(" ");
            Serial.print(Version);
            Serial.println(" HS3");
            delay(100);
            Serial.print("Connected ");
      #endif
            delay(100);
            break;
          case 'K':
            delay(200);
      #if ISIP == 1
            Udp.print("Alive ");
            Udp.endPacket();
            if (Udp.remoteIP() != ServerIP) {
              ServerIP=Udp.remoteIP();
              #ifdef ESP8266
              EEPROM.commit();
              #endif
      #else
            Serial.print("Alive ");
      #endif
            break;
            case 'r':
            delay(200);
            resetFunc();  //call reset
            break;
          case 'O':
            FromHS[Byte3] = Byte4;
            break;
          case 'D':
            break;
      void SendToHS(byte Device, long Data){
      #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
      #else
        Serial.print(" API ");
        Serial.print(Device);
        Serial.print(" ");
        Serial.println(Data);
      #endif
      void SendToHS(byte Device, int Data){
      #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
      #else
        Serial.print(" ");
      #endif
      void SendToHS(byte Device, float Data){
      #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
      #else
        Serial.print(" ");
      #endif
      void SendToHS(byte Device, double Data){
      #if ISIP == 1
        Udp.beginPacket(Udp.remoteIP(), ServerPort);
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
      #else
        Serial.print(" ");
      #endif
        I am a little confused by your code:
        PHP Code:
        if(millis() - LastSend SendDelay){
        ami digitalRead(Input8);
        SendToHS(1,ami);
        LastSend=millis();
        In this code you are using SendToHS(1,ami); to send the status of pin 8 to the API input 1 device but then in the next line of code you are using SendToHS(1,dht.readHumidity()); to also send the Humidity reading to API input 1.
        I think the NAN is the sensor not having time to read the value or it is erroring out.
        Try this untested code:
        PHP Code:
           V1.0.0.134
        int Output1 5;
        //int Output2 = 6;
        #define ISIP 1
        #define ESP8266 1
        #include <EEPROM.h>
        const byte BoardAdd 7;
        byte mac[] = {0x000xAA0xBB0xCC0xDE0x07};
        IPAddress ip(192168137);     //IP entered in HS config.
        IPAddress gateway(19216811);     //Gateway
        IPAddress subnet(2552552550);     //Gateway
        IPAddress HomeseerIP(192168115); //Homeseer IP address
        const unsigned int localPort 8080;      //port entered in HS config.
        byte EEpromVersion EEPROM.read(250);
        boolean IsConnected false;                             // *
        WiFiUDP Udp;                                             // *
        const unsigned int ServerPort 8888;                    // *
        #include <DHT.h>
        #define DHTPIN 2
        #define Input8 D8
        DHT dht(DHTPINDHTTYPE);
        int SendDelay 3000
        long LastSend
        int ami 1034;
        void setup() {
        HSSetup();
        dht.begin();
        pinMode(Output1OUTPUT);
        pinMode(D8INPUT);
        void loop() {
        IsUDP();
        if (
        SendToHS(1,ami);
          // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
        float h dht.readHumidity();
        // Read temperature as Celsius (the default)
        float t dht.readTemperature();
        // Check if any reads failed and exit early (to try again).
        if (isnan(h) || isnan(t)) {
           return;
        SendToHS(1,h);
        SendToHS(2,t);
        LastSend=millis();
        charVersion "API1.0.0.136";
        int Byte4,Byte5;
        void HSSetup() {
        EEPROM.begin(256);
        ServerIP IPAddress(EEPROM.read(2),EEPROM.read(3),EEPROM.read(4),EEPROM.read(5));
            if (
        EEPROM.commit();
        EEpromVersion=22;
        WiFi.begin(ssidpass);
        WiFi.config(ipgatewaysubnet);
          while (
        delay(500);
        Udp.setTimeout(0);
        delay(1000);
        SendConnect();
        IsConnected false;
        void SendConnect()
        #if ISIP == 0
        #else
        Udp.endPacket();
            if (
        Udp.endPacket();
        #endif
        #if ISIP == 1
        void IsUDP(){
        int packetSize Udp.parsePacket();
          if(
        packetSize)
        LastRcvIP Udp.remoteIP();
        Udp.read();
        Byte2 =Udp.read();
        DataEvent();
        #else
          while (
        delay(17);
        Byte1 Serial.parseInt();
        Serial.read();
        Byte2 Serial.read();
        Byte3 Serial.parseInt();
        Byte4 Serial.parseInt();
        Byte5 Serial.parseInt();
        DataEvent();
        #endif
        D Disconnect
        r reset
        K Keepalive
        C Connect request
        void DataEvent() {
        if (
            switch (
        Byte2) {
            case
        'c':
        IsConnected true;
        #if ISIP == 1
        ServerIP=LastRcvIP;
        #ifdef ESP8266
        EEPROM.commit();
        #endif
        #endif
        break;
            case
        'C':
        #if ISIP == 1
        Udp.beginPacket(LastRcvIPServerPort);
        Udp.print(" ");
        Udp.print(Version);
        Udp.endPacket();
        delay(100);
        Udp.endPacket();
        #else
        Serial.print(" ");
        delay(100);
        #endif
        delay(100);
        IsConnected false;
              break;
            case
        'K':
        delay(200);
        #if ISIP == 1
        Udp.endPacket();
              if (
        #ifdef ESP8266
        EEPROM.commit();
        #endif
        #else
        #endif
        break;
              case
        'r':
        delay(200);
        break;
            case
        'O':
              break;
            case
        'D':
        IsConnected false;
              break;
        void SendToHS(byte Devicelong Data){
        if (
        #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
        #else
        Serial.print(" ");
        #endif
        void SendToHS(byte Deviceint Data){
        if (
        #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
        #else
        Serial.print(" ");
        #endif
        void SendToHS(byte Devicefloat Data){
        if (
        #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
        #else
        Serial.print(" ");
        #endif
        void SendToHS(byte Devicedouble Data){
        if (
        #if ISIP == 1
        Udp.print(" API ");
        Udp.print(Device);
        Udp.print(" ");
        Udp.print(Data);
        Udp.endPacket();
        #else
        Serial.print(" ");
        #endif
        Greig.
        Scripts =
        Various
          Thank you, I will try this out. I should have apologized in advance, Im a copy paste user taking bits and pieces from others to try and get my stuff to work since i really am not a good coder.
          So I'm my code looks like it has things that don't make sense its not intentional
