Hi All,
I have omnistat 3 installed and its linked to an HAI RC-80 thermostat.
Being in Australia I am running celsius.
I am getting an error reporting in the app a few times each hour and also in the startup log that says:
8:28:06 AM ~ Error converting Celsius 180 degrees to Omnitemp degrees. Message: Index was outside the bounds of the array.
8:21:36 AM ~ Error converting Celsius 190 degrees to Omnitemp degrees. Message: Index was outside the bounds of the array.
The Celsius number seems to change.
In the HS startup log it says:
2/26/2018 6:40:50 PM ~!~Omnistat 3~!~Error converting Celsius 290 degrees to Omnitemp degrees. Message: Index was outside the bounds of the array.Startup Complete, 1 errors detected, check the log for more information.
The plugin is controlling the thermostat ok so its not affecting functionality just filling logs with entries I would like to stop.
Any ideas?
Nick
Any ideas?
Nick
