Go Back   HomeSeer Message Board > Developer Support > Scripts & Plug-Ins:Development and Libraries > Script & Plug-In Library Discussion
Script & Plug-In Library Discussion This forum is for discussing scripts that are posted in the Script Library. To keep the Script Libray as neat as possible, replies are not permitted in that forum. Please post questions, comments, scripts in process, etc. to this forum.
Old August 6th, 2010, 01:20 PM
wpiman's Avatar
wpiman wpiman is offline
Google Latitude script
This is the discussion for the Google latitude script. This script is pretty basic, but it fundamentally changed the way I used Homeseer and I think it may do the same for others.
It is found here.
I am not a software programmer, so bear in mind it is rough-- but useful nonetheless.
http://board.homeseer.com/showthread.php?t=143249
HS 2.5.0.21; Z-Seer 1.2 with ZStick (38 devices)
Operating System: Microsoft Windows XP Professional - Work Station;
Plug-Ins Enabled: ZWave Thermostats, HSTouch Server, TED, HSTouch Server Unlimited,
Media Player, HSTouch iPhone, CheaperRFID Plugin, AC RF Processor,
iTunes, WeatherPLUG
HSM100, HRDS1, Schlage Locks, WebController, WDT20, WGL..............
Second house....
2.4.0.72 Zstick
5 2Gig thermostats, Kwikset locks
Old August 6th, 2010, 01:52 PM
wpiman's Avatar
In answer to a question about line 24....
Try adding "temp" to line 13.
ie. dim cuurentCoridinates, temp, latitude.....
Next that doesn't work-- you may need to add
ScriptingReferences = System.xml;System.xml.dll
To your config/settings.ini file under
[Settings]
Old August 6th, 2010, 01:58 PM
TrOjAn's Avatar
TrOjAn TrOjAn is offline
Super Seer
Added Temp as stated and ran the event, same error, checked my settings.ini and that line is there already (for some of Jon00s)
Thanks, TrOjAn
Old August 6th, 2010, 02:00 PM
wpiman's Avatar
Hmmmm,
Can you send me your userID number-- I want to look at your badge.
Are you by chance east of the prime meridian?
I wonder if that is causing something.....
Old August 6th, 2010, 02:05 PM
TrOjAn's Avatar
Super Seer
SUre can, can I email it? I dont want to post it here.. thanks
Old August 6th, 2010, 02:07 PM
wpiman's Avatar
Sure
gmail----
wpiman
Old August 6th, 2010, 02:23 PM
TrOjAn's Avatar
Super Seer
Now working yhanks to wpiman,
the latitude code needed a - in front of the number...
TrOjAn
Old August 6th, 2010, 02:31 PM
wpiman's Avatar
Glad it is working---
I don't have a minus sign-- perhaps they dole out signed numbers.
So I guess double check the sign of your Userid.
Old August 8th, 2010, 06:46 AM
travisdh travisdh is offline
Super Seer
Thanks for the script post, this is fantastic and is something I have implimented in my setup. I have a query though, I was hoping you might be able to help me. I have a device (Z15) which is a virtual device that I am calling TH Suburb Occupancy. What I want to be able to do is set it so that when the position code (Z1) string = "Beaconsfield Upper VIC, Australia" or "Pakenham, VIC, Australia" to set the Z15 device to "ON" and when it does not equal either of those to set it to "Off". This will allow me to set house occupancy based on suburb (especially for fire calls) as chances are in my case if I am in either suburb I am available for calls and the house can allow events to run if required.
Can anyone give me a hand with a simple script, I tried a few if else statements but all errored up, or showed "Off" when they should have shown on.
Old August 8th, 2010, 04:15 PM
Snelvuur's Avatar
Snelvuur Snelvuur is offline
Seer Plus
have not tried it yet, but perhaps a quick question up front. Do you know if its possible that it will show you somehow on which highway your driving?
Old August 8th, 2010, 08:54 PM
wpiman's Avatar
Right now latitude does not provide that information. If they do, it would be easy to add.
As for the other question, that could be done in the script, but an easier way would be to have an event fire when that status changes, and compare it there and set your virtual device.
Old August 9th, 2010, 12:22 AM
Super Seer
does the status change based on the position you are currently at?.
I know the string does, but at the moment there is no way to have an event to fire if string = x
How might I get it to show the status of Upper Beaconsfield?
Old August 9th, 2010, 12:48 PM
drozwood90 drozwood90 is offline
So, I see how I am getting geo-position data, but how are you using it to say you are "in" an area?
--Dan
Old August 9th, 2010, 01:45 PM
TrOjAn's Avatar
Super Seer
Originally Posted by zebrafilm View Post
I get this error:
Script compile error: 'Let' and 'Set' assignment statements are no longer supported.on line 28
I am in Europe so it might be the same minus sign error?
Can you be a bit more specific what you changed to get it working?
Thanks for the scripting effort, it look promising.
Bastiaan
That error is because you have renamed the .txt to .vb, it should be .txt
TrOjAn
Old August 9th, 2010, 04:53 PM
Jakob.Sand's Avatar
Jakob.Sand Jakob.Sand is offline
This looks great.
It is found here.
Best,
Jakob Sand, I automate everything!
Old August 9th, 2010, 10:15 PM
Super Seer
Because the position code shows the suburb you are currently in. With my example if I am in suburb X, chances are I am at home, or available. Rather than using the Lat / Long i use the suburb.
Old August 10th, 2010, 05:19 AM
Snelvuur's Avatar
Seer Plus
i get :
10-8-2010 0:38:37 - Error - Running script, script run or compile error in file: getPosition.txt424:Object required: 'temp(...)' in line 21 More info: Object required: 'temp(...)'
while my atom badge url does show the geoip locations. (the test url sort of speak)
Old August 10th, 2010, 07:05 AM
Gotcha, I'm noticing in my area, it tells me I'm in Rochester, NY or New York, NY.
Which is NOT the case. I am in Rochester when at work, and in my suburb at night. Oh well, I guess I can always use circle math against the coordinates.
--Dan
Old August 10th, 2010, 08:30 AM
wpiman's Avatar
i get :
This shows up in my log on occasion. I think this occurs when the site cannot be accessed. I run the script every minute, I might see it once a day. Do you see it consistently? I think i can add something which will remove this error and make it a warning.
I am on vacation, so I might not get to it for A few days. Typing this on my iPhone,
Old August 10th, 2010, 09:40 AM
Snelvuur's Avatar
Seer Plus
dont see those errors anymore now though..
HTML code is On
