Jon00 WiFi LED Lamp Controller (Limitless MiLight EasyBulb)
    Homeseer 2 and Homeseer 3 versions available!
    ***** PLEASE NOTE THAT THIS DOES NOT WORK WITH THE NEW MILIGHT WiFI iBOX V6 CONTROLLERS (Tested on V3 and V4 controllers only) *****
    This unmanaged plugin/client/application allows you to control specific Wi-Fi LED lamps via Homeseer or via the application interface. These lamps are manufactured in China under the following brand names: Limitless LED, dekolight, iLight, applight, applamp, LEDme, EasyBulbhere.
    Jon
    Wow, what can I say. Well thanks Jon. Anyway, now I must include the wifi led bulbs. Of course I will support you
      Hi Jon,
      Order placed for my work!
      Is there an easy way to control the lamps from a pc without homeseer?
      Where did you find all the info on the lamps or did you reverse engineer something to find out.
      Thanks for any help with this in advance.
      Greig.
      Scripts =
      Various
        Provided the Homeseer Dll's are in the same directory as the client, you can run the application without connecting to Homeseer i.e. not providing a username/password in the settings. You will not be able to run any home designed effects though.
        There are loads of sites showing the api for these lamps. Look at this post: http://board.homeseer.com/showthread.php?t=159498
        Jon
          Great thanks for the info I didn't see that thread.
          Greig.
          Scripts =
          Various
            Take a look at this thread too: http://board.homeseer.com/showthread.php?t=159514
            Jon
              I forgot to mention...you could always connect remotely to Homeseer with the client. You could then control the lights at work via your home!
              Jon
                mmmmm...Sounds like fun but could be dangerous. I am not so sure this is a good plan as I may get fed up at home and decide to change the colour of the front of the theatre.
                Thanks again for your help.
                Greig.
                Scripts =
                Various
                  Hello, I followed all the installation, but can not start, the info is: Jon00 wifiLed buld stopped working and nothing happens, how it go?
                  loup
                    Did you copy the 3 Homeseer files across to the client directory?
                    Jon
                      Yes, I have copied the file, HomeSeer 2 HS2 util, Scheduler, Jon00 WiFiLedBuld all the file in one folder, C: Jon00WiFiLED I work with W7 and Homeseer 2.5.0.80, when I want to open Jon00WiFiLedBuld Windows indicates that it has closed this program. It probably miss missing something, but what? Thank you for your help I really appreciate.
                      loup
                        Can you please list all the files that you have in the client directory.
                        Do you run Homeseer with a English or French version of W7?
                        Jon
                          ok
                          In the C: Jon00WiFiLED
                          Homeseer2
                          HS2Util
                          jon00 WiFiLEDBuld
                          Scheduler
                          yes, I use the French version of W7
                            I've just put a copy on Windows 7 set to regional settings Canada - French and it is working fine here.
                            Can you tell me what the error message shows exactly.
                            Jon
                              I've just put a copy of Windows 7 set to regional settings Canada - French and it is working fine here.
