Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 Plug-In Development
HS3 Plug-In Development Discussions related to developing plugins for HS3.
Old May 29th, 2013, 03:42 PM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
HS3 Plugin Samples
[UPDATED 5/14/15]
Here are 3 plug-in samples that show the 3 ways to configure a plugin. One is a standard sample, one is a more basic sample that has simple actions/triggers, and the third shows how to create a multi-instance plugin.
https://homeseer.com/updates3/hs3_plugin_samples.zip
10/19/13 Changes:
* Modified multi-instance sample so it supports both single and multiple EXE modes properly
Old June 7th, 2013, 01:55 PM
mnsandler's Avatar
Insteon Overlord
please add a version number to the zip file name so we can keep them straight as they change.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old June 7th, 2013, 03:57 PM
dcorsus dcorsus is offline
Can we have an example for dynamic (AJAX) webpages
ftp://ftp.homeseer.com/updates/Beta/...in_samples.zip
Could you extend the sample, with an Ajax handler and put in a control that gets dynamically updated let's say every second (ex a counter).
I agree with Mark, please give it a version number, hard to keep track of whether I have the latest.
Dirk
ps. the sample wouldn't run under Studio because it was missing an inherited declaration for the "SpeakIn" method, I fixed that on my setup and now I can debug the sample under 3.0.0.1 (or was it 2?)
Old June 7th, 2013, 04:24 PM
rjh's Avatar
rjh rjh is offline
That is what I did in the sample, it has an AJAX call that updates a div that is the time and date, so you can see it change in real time.
The plugins I just uploaded are the very latest. I will update the post with a date when I change them.
Dirk
Old June 7th, 2013, 07:03 PM
Rotech's Avatar
Rotech Rotech is offline
[UPDATED 6/7/2013]
Is this for developers only? Or this is a "how to" info?
Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Old June 7th, 2013, 07:29 PM
rjh's Avatar
rjh rjh is offline
The samples are source code to 3 plugins. If you are not a programmer, I doubt they are of any use.
Old June 7th, 2013, 07:31 PM
Rotech's Avatar
Kinda figured that, thks...
Old June 7th, 2013, 07:55 PM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
Hector... yes U and I have no business looking at them!!!!!!!
let the guru's figure it out!!
Plugins - BLRF 2.0.93.0 | Concord 4 3.1.13.9 | HSTouch Server 3.0.0.68 | RFXCOM 30.0.0.36 | X10 3.0.0.36 | Z-Wave 3.0.1.190
Old June 8th, 2013, 04:05 PM
Gogs's Avatar
Gogs Gogs is offline
Nice touch Rich, good to in an open forum that HST is trying to help those developers that are insterested pointing in the right direction.
HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
Old July 29th, 2013, 10:14 AM
WiseSeer WiseSeer is offline
Is there a HOWTO or beginners guide to homeseer plugin/custom web page development? I've reviewed the SDK documentation and it makes assumptions about how to even start. (Yes, I'm a developer but of low level OS/drivers, but not web/java/scripts -- just starting there)
Old July 29th, 2013, 11:39 PM
vasrc's Avatar
vasrc vasrc is offline
If there is I haven't found it yet
The information you need is in the SDK and samples, there's just no overall design doc that show how it all fits together. I found the HSPI_SAMPLE to be the most useful albeit more than you might use. Another confusing thing for me was how the same process was coded slightly different in each example.
In the end i just slugged my way through it, it's just another language and/or API. If you can write low level drivers you shouldn't have a problem other than a lot more time to fill in the blanks.
Being a Beta doesn't help either as you're never sure if it's your misunderstanding something or just a bug
Have fun
Z
Old July 31st, 2013, 09:46 AM
I don't think my question is specific to ver 3. Please walk me though creating a simple custom page. I've added simple internal and extern URLs in the Tools->Setup->Custom->Custom Page 1 URL [e.g., test.html] but I don't see a new page. Added the test.html file to the homeseer html folder. How do I add a custom page?
Old July 31st, 2013, 10:20 AM
vasrc's Avatar
Sorry, HS3 is eating away at my brain
I'm assuming you entered in the page name in the URL section (It's homebased to /html already, so just the page name, ie test.html)
You'll get a new button on your header that has the title you gave it. You can access it from there.
Z
Old August 6th, 2013, 08:41 AM
Got it, thanks.
Old October 18th, 2013, 12:40 PM
tonlof's Avatar
tonlof tonlof is offline
I have some problem to get SAMPLE & SAMPLE_BASIC to work. I have not done any changes in the code yet.
Using Visiual Studio Express 2012
HSPI_SAMPLE (Can't build, 102 errors)
HSPI_SAMPLE_BASICMI (Works Perfect) I have made my own plugin with this, but don't want multiple instances.
HSPI_SAMPLE_BASIC (Build is working but I got error when activate the plugin, see error below)
Initializing plug-in(2): Sample-Basic Instance::Conversion from string "COM1" to type 'Long' is not valid.0STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old October 18th, 2013, 12:42 PM
I think you don't have the latest version of the sample code. In HS3 version 13 (or so) the comport was changed from string to integer and I believe the sample code went from v3 to v5 (or something like that).
Dirk
Old October 18th, 2013, 12:44 PM
tonlof's Avatar
Thanks for your quick reply, I download it from the first post in this thread.
Dirk
Old October 18th, 2013, 01:14 PM
So it is OK now or you had these errors with the downloaded code? If you have these errors with the latest code, I'm not familiar with error 102 but you have to check all the references and make sure they are still properly pointing to the right dlls, coms etc in the right directories. If the basic-sample PI is giving you the com port error, just look at Init_IO of the other version, look at how the procedure definition was changed from string to integer and do the same, save it and you should be fine.
Dirk
Old October 18th, 2013, 01:24 PM
vasrc's Avatar
If you show 102 errors it means you haven't referenced the HS libraries (Scheduler, HomeSeerAPI, HSCF) yet.
Make sure you point at them on your References page
Old October 18th, 2013, 01:29 PM
rjh's Avatar
rjh rjh is offline
I updated the samples, download using the link in the first post.
