Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help > How-To's
How-To's This area provides in-depth information on how to do something in HomeSeer or home automation.
Closed Thread
Old November 12th, 2013, 05:48 PM
jseer's Avatar
jseer jseer is offline
HomeSeer Manager
HS Logo How to Add A Z-wave Interface (controller) to HS3
This tutorial is on adding a Z-wave controller to HS3. We begin by going to the Plug-ins tab in the navigation and then to the Z-wave option which prompts our last menu. Select Controller Management
Once that page loads, click the Add Interface button to begin the management process.
You will then be given the option to name your interface, select the interface model, and pick the corresponding COM port. The interface model will be whichever z-wave controller you have. The COM ports that are actually plugged in will be the only ones that show up in the list.
Once all of the information is correct, go ahead and click Add
When initializing, you will get a screen like this:
Once the z-wave controller has been contacted and initialized, you will need to enable the controller to create the network and complete the adding process.
Once enabled you should see a screen like this:
Your network is createed and the Z-troller and HomeSeer are communicating. The actions drop down is where you will perform any actions with your z-wave controller.
Jon Smith
Closed Thread
Tags
controller, hs3, z-wave
HTML code is On
Frequent "Z-wave interface Z-Wave interface did not fully initialize..." messages Kirkla79 SmartStick+ 2 May 29th, 2017 06:16 PM
Handheld controller/interface problems dlgardne HomeSeer Wall Dimmers & Switches 2 October 19th, 2016 07:34 AM
2ndary Z-Wave Controller Z-Wave Status Question? Pete HomeSeer Z-Wave Plug-in 0 February 22nd, 2016 04:02 PM
Failed sending Z-Wave command to device(s): Z-Wave Z-Wave Interface brbjr HomeSeer Z-Wave Plug-in 0 December 28th, 2009 10:49 PM
Reliable x10 PC interface controller!?! Bestgear General Home Automation Hardware Discussion 6 February 16th, 2006 12:00 AM
