Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old January 12th, 2014, 09:11 AM
mrhappy mrhappy is offline
HS3 Third Party Current Cost Envi Plugin Released
All
I have now got a stable enough version (I hope, well it has been tested by quite a few people) of my Current Cost Envi Plugin for HS3. This is in part modeled on the HS2 plugin I wrote but should not be considered a direct replacement, some functions have been removed.
It is relatively simple to get working and can be installed from the updater.
It will produce one HTML page with nine charts (eight from the history database, one from a collection of values during the day) and two tables for daily/monthly data.
Any issues post them here and I will do my best to sort them out.
Plugin is now in the updater
Documentation & Release Notes: Link
Old January 12th, 2014, 02:33 PM
gearyt's Avatar
gearyt gearyt is offline
Super Seer
are you sure, to just put the zip is Homeseer HS3 ? not in download zips ?
isn't doing anything for me
Ubuntu 16.10 (64) | HSPro 3.0.0.297 | Z-Wave 3.0.1.124 | Server .94 | BL BackUp | BLOccupied | BLLock | Media Controller | Jowi HUE | HSTouch | DSC-Envisalink | I-Tunes DAAP | DirecTV | Restart | Honeywell WiFi | Weather XML | RFX Com | + Android .117 : IOS 8
Old January 12th, 2014, 02:37 PM
Rupp's Avatar
Rupp Rupp is offline
Did you decompress the zip and put the files in the locations where the instructions stated?
-Rupp
I meant the files from that zip file should be dropped into the HS directory sorry I was not clear, I'll edit the post. Drop them in so that HSPI_CCOST3P.exe is with the other plugins.
Old January 12th, 2014, 05:49 PM
gearyt's Avatar
Super Seer
thanks.. installed waiting for first update..
was I supposed to get the second bank of devices ?
Old January 12th, 2014, 06:13 PM
You should get just one set of those base devices (with the address starting CCB-) and then a set of other devices based on how many sensors you have in the system. You saying you have two sets of base devices?
Old January 12th, 2014, 07:07 PM
gearyt's Avatar
Super Seer
just basic unit, with one set of sensors.. no movement on charts
was there a config page I missed ?
Old January 12th, 2014, 08:16 PM
Charts will take the very minimum of a couple of hours to get produced unfortunately so hang in there, there is no config page as I tried to get away with config/ini files - is there something you need to configure?
Old January 12th, 2014, 10:01 PM
GaryDN GaryDN is offline
is this newer than 1.01 ?
Old January 12th, 2014, 11:47 PM
jlikonen's Avatar
jlikonen jlikonen is offline
Mrhappy,
Your plugin looks really great. I'll certainly test it when I start using HS3 on my production system.
Old January 13th, 2014, 06:54 AM
There have been changes and it is newer yes, for the testing versions I did not change the version number so if there are future releases then I will change the version number.
Old January 13th, 2014, 11:02 AM
gearyt's Avatar
Super Seer
nope, just wanted to make sure I set it up right as I am missing devices
looks like I have a com problem, nothing is changing
Old January 13th, 2014, 12:21 PM
Do you have the HS plugin running still? You can only have one plugin talking to the envi at a time. The log should also say whether it has been able to open the com port.
Old January 13th, 2014, 12:35 PM
gearyt's Avatar
Super Seer
old CC is long gone..
might be something dumb like being unplugged. need to go home and check
Old January 13th, 2014, 01:37 PM
8r1an 8r1an is offline
Hi
I have an EnviR but i have not been able to find the power supply since moving house.
Can someone have a look and let me know what the power supply voltage is for the console
Thanks.
Brian
XP SP3, HS Pro 2.5.0.81
RFXCOM, BLBackup, BLRadar, Sonos, HSTouch, DR IP/Serial, Jon00Bluetooth
Jon00Network, mrhappy Cumulus, mcsXap, Ultra1Wire2, UltraNetcam
Old January 13th, 2014, 01:45 PM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
This is great!!!
Will this be able to use usage tiers to formulate costs? We are on a tier rate system here and it would be great to be able to follow that model when using the projected costs in the plugin.
Tier 1 = 0-450kWh = $.11/kWh
Tier 2 = 451-750kWh = $.15/kWh
Tier 3 = 751-1100kWh = $.19/kWh
Tier 4 = 1101+kWh = $.26/kWh
Transitioning to HS3Pro .298 - WinXPEmbedded
Old January 13th, 2014, 01:49 PM
hmm, the port is at least found so the USB adaptor won't be unplugged, double check the port and one thing to do is enable developer mode to see if that shows data coming in.
Old January 13th, 2014, 01:50 PM
Originally Posted by 8r1an View Post
Hi
Thanks.
I'm sure it is 3v 300ma but I'm at work at the moment, I might even have a spare (need to check though) if you want it.
Old January 13th, 2014, 01:54 PM
Originally Posted by Dafunktyfunk View Post
This is great!!!
Sorry to get your hopes up but it won't do what you are after, not to say you couldn't perform your own your own queries on the database but it is simply designed differently. It is not designed to work out costs, just get power use data.
Old January 13th, 2014, 09:42 PM
gearyt's Avatar
Super Seer
wrong com port
off and running !! Looks GREAT !
Current Cost Envi Plugin (3rd Party) - Testers Wanted mrhappy Script & Plug-In Development 209 June 7th, 2014 02:00 PM
Current Cost Envi - where's the data? Silentcossack HS3 / HS3PRO Discussion 14 January 13th, 2014 07:56 PM
Current Cost Envi bad data happnatious1 HS3 / HS3PRO Discussion 5 December 28th, 2013 01:19 PM
