Anyone got any API code or tips on how to read these cheap humidity sensors. I've got dreams of controlling my bathroom extractors.
Thanks.
Thanks.
//For serial set to 0 and for Ethernet set to 1
#define ISIP 0
//Do NOT modify these
#if ISIP == 1
#include <EEPROM.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#endif
*Arduino to Homeseer 3 Plugin API writen by Enigma Theatre.*
* V1.0.0.36 *
*******Change the values below only*************************
//Address of the board.
const byte BoardAdd = 1;
#if ISIP == 1
// Enter a MAC address and IP address for your board below.
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// The IP address will be dependent on your local network.
IPAddress ip(192,168,0,100); //IP entered in HS config.
const unsigned int localPort = 9000; //port entered in HS config.
IPAddress HomeseerIP(192,168,0,123); //Homeseer IP address
IPAddress ServerIP(EEPROM.read(2),EEPROM.read(3),EEPROM.read(4),EEPROM.read(5));
byte EEpromVersion = EEPROM.read(250);
#endif
//************Do not change anything in Here*****************
int FromHS[10]; // *
boolean IsConnected = false; // *
#if ISIP == 1 // *
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; // *
EthernetUDP Udp; // *
const unsigned int ServerPort = 8888; // *
#endif // *
void(* resetFunc) (void) = 0; // *
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
int SendDelay = 3000;
long LastSend;
void setup() {
HSSetup();
//Add YOUR SETUP HERE;
dht.begin();
void loop() {
#if ISIP == 1
IsUDP();
#endif
//Add YOUR CODE HERE;
/* To Send Data to Homeseer use SendToHS(Device,Value)
Eg.. SendToHS(1,200); where 1 is the API device in homeseer and 200 is the value to send
To Recieve data from Homeseer look up the FromHS array that is updated when the device value changes.
Eg.. FromHS[5] would be the data from API Output device 5
All code that is located just below this block will execute regardless of connection status!
You can include SendToHS() calls, however when there isn't an active connection, it will just return and continue.
If you only want code to execute when HomeSeer is connected, put it inside the if statement below.
/*Execute regardless of connection status*/
if (IsConnected == true) {
if(millis() - LastSend > SendDelay){
SendToHS(1,dht.readHumidity());
SendToHS(2,dht.readTemperature());
LastSend=millis();
/*Execute ONLY when HomeSeer is connected*/
const char* Version = "API1.0.0.36";
byte Byte1,Byte2,Byte3;
int Byte4,Byte5;
void HSSetup() {
#if ISIP == 1
if (EEpromVersion!=22) {
ServerIP=HomeseerIP;
EEPROM.write(2,ServerIP[0]);
EEPROM.write(3,ServerIP[1]);
EEPROM.write(4,ServerIP[2]);
EEPROM.write(5,ServerIP[3]);
EEPROM.write(250,22); //Store the version where the eeprom data layout was last changed
EEpromVersion=22;
Ethernet.begin(mac,ip);
Udp.begin(localPort);
Udp.setTimeout(0);
delay(1000);
SendConnect();
#else
Serial.begin(115200);
Serial.flush();
Serial.setTimeout(0);
delay(1000);
Serial.print("Connect ");
Serial.println(BoardAdd);
#endif
void SendConnect()
#if ISIP == 0
#else
Udp.beginPacket(ServerIP,ServerPort); //First send a connect packet to the dynamic IP stored in eeprom
Udp.print("Connect ");
Udp.print(BoardAdd);
Udp.endPacket();
if (ServerIP!=HomeseerIP) {
Udp.beginPacket(HomeseerIP,ServerPort); //Then if the stored value doesn't match the pre-specified one, send a connect packet there also
Udp.endPacket();
#endif
#if ISIP == 1
void IsUDP(){
int packetSize = Udp.parsePacket();
if(packetSize)
IPAddress remote = Udp.remoteIP();
Byte1 =Udp.parseInt();
Udp.read();
Byte2 =Udp.read();
Byte3 =Udp.parseInt();
Byte4 =Udp.parseInt();
Byte5 =Udp.parseInt();
DataEvent();
#else
void serialEvent() {
while (Serial.available() > 0) {
delay(17);
Byte1 = Serial.parseInt();
Serial.read();
Byte2 = Serial.read();
Byte3 = Serial.parseInt();
Byte4 = Serial.parseInt();
Byte5 = Serial.parseInt();
DataEvent();
#endif
Used Data Input Cases
D Disconnect
r reset
K Keepalive
O PinMode Output Set
d Input debounce time set
C Connect request
c Connection established - report current status
void DataEvent() {
if (Byte1 == BoardAdd) {
switch (Byte2) {
case 'c':
IsConnected = true;
#if ISIP == 1
if (Udp.remoteIP() != ServerIP) {
ServerIP=Udp.remoteIP();
#endif
break;
case 'C':
#if ISIP == 1
Udp.beginPacket(Udp.remoteIP(), ServerPort);
Udp.print("Version ");
Udp.print(" ");
Udp.print(Version);
Udp.println(" HS3");
Udp.endPacket();
delay(100);
Udp.print("Connected ");
Udp.println(BoardAdd);
Udp.endPacket();
#else
Serial.print("Version ");
Serial.print(BoardAdd);
Serial.print(" ");
Serial.print(Version);
Serial.println(" HS3");
delay(100);
Serial.print("Connected ");
#endif
delay(100);
break;
case 'K':
delay(200);
#if ISIP == 1
Udp.print("Alive ");
Udp.endPacket();
#else
Serial.print("Alive ");
#endif
break;
case 'r':
delay(200);
resetFunc(); //call reset
break;
case 'O':
FromHS[Byte3] = Byte4;
break;
case 'D':
break;
void SendToHS(byte Device, long Data){
#if ISIP == 1
Udp.print(" API ");
Udp.print(Device);
Udp.print(" ");
Udp.print(Data);
Udp.endPacket();
#else
Serial.print(" API ");
Serial.print(Device);
Serial.print(" ");
Serial.println(Data);
#endif
