Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3Touch™ > HS3Touch Designer
HS3Touch Designer Discussions regarding HS3Touch Designer (for use with all clients)
Old April 4th, 2015, 11:59 AM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
HSTouch Designer Release Notes
Install the latest by restarting your Designer, or download from the homeseer.com downloads page from the support page.
Update 3.0.0.30 is available, install from the downloads page at homeseer.com.
Changes in 3.0.0.30:
* Faster loading of the application
* Timeouts on connections have been extended for deployment on slower connections and over MyHomeSeer
* When deploying it creates the file DeployLog.txt in the program folder that lists all files deployed
Changes in 3.0.0.25:
* Added more alignment options to the toolbar
* Fixed associating a drop list with a device now displays all controls
Rich,
Old June 10th, 2015, 06:21 PM
heatvent's Avatar
heatvent heatvent is offline
Guys...it would be great to get a consistent view/history of release notes. Looking at the above, there are only two releases described, dates are not provided, etc. I came here to see if the talked about Music API has ever been implemented in HSTouch for HS3 but it is entirely unclear. There was a post in January saying it would be coming out soon but no mention in the two version posts above and no idea if these came out before or after the post on the board.
Old June 11th, 2015, 09:03 PM
rjh's Avatar
rjh rjh is offline
We are currently working on a Spotify plugin and are using that to test the media API, so it will available soon. It actually is in there now and there are couple of plugins using it but there will be some additions.
Old June 12th, 2015, 07:12 AM
lhfarm lhfarm is offline
Anyone looking at fixing bugs
I've submitted a bug and I know others have too, related to the handling of pick lists in the latest version. Have heard nothing. Are bugs being addressed?
Barry
Old June 12th, 2015, 09:06 AM
rjh's Avatar
rjh rjh is offline
We will get to HSTouch soon, not working on HSTouch bugs at the moment.
Barry
Old October 10th, 2015, 09:16 PM
ozinnewy's Avatar
ozinnewy ozinnewy is offline
Devices not available in Designer
I have just added a new room and a new virtual device. I have opened HSTouch designer, however the new room and the device are not listed. I tried changing the new device to an existing room, but the device still does not show in the designer. It appears that designer is not refreshing the room list or devices. The device is not hidden and is available to all users.
Old October 10th, 2015, 10:11 PM
mwaite's Avatar
mwaite mwaite is offline
Did you try restarting HSTouch Server plugin?
Mike
Old October 10th, 2015, 10:21 PM
ozinnewy's Avatar
Thanks Mike, restarted HS3 just to be sure and can now see new room and device is HSDesigner.
Old October 11th, 2015, 09:46 AM
rjh's Avatar
rjh rjh is offline
There is a refresh Icon on the toolbar in the Designer, that should cause the Designer to fetch the latest device/event info.
Old October 13th, 2015, 12:15 PM
skarragallagher skarragallagher is offline
Is it too soon to ask about the status of these projects and the media API. Apparently some of the media plugin devs have posted many bugs with the incomplete media API that have yet to be addressed.
there is no time like the present...
Old June 18th, 2017, 03:20 PM
ramshaklez ramshaklez is offline
Seer Plus
Circles
Is it true that the official release of HSTouch Designer is still on .30? I am also a little confused where to track the latest release for the Designer.
In the Beta forum, the latest sticky post only shows up to version 1.0.0.19:
https://forums.homeseer.com/forumdisplay.php?f=1236
But, in the main Designer forum, I see a sticky post for 3.0.0.51:
https://forums.homeseer.com/forumdisplay.php?f=1238
Shouldn't 3.0.0.51 show up in the beta Designer forum and not the main Designer forum? Otherwise, what's the point of having the beta forum?
Old June 19th, 2017, 11:10 AM
rjh's Avatar
rjh rjh is offline
Yes, a bit confusing. I moved the .51 Beta post to the HS3Touch Beta forum.
Old July 26th, 2017, 01:22 PM
morrisdlx's Avatar
morrisdlx morrisdlx is offline
HSTouch Designer Txt file error
As stated, the newest version of HSTouch Designer "creates the file DeployLog.txt in the program folder that lists all files deployed".
I have a HomeTroller S6 Pro and use a Microsoft Surface Pro 3 to craft my HSTouch projects. When I field an update I get an error message stating that it could not create the file. I know this is most likely a permissions issue on the tablet but was wondering if anyone else had seen this and resolved the issue.
Old July 26th, 2017, 02:14 PM
happnatious1's Avatar
happnatious1 happnatious1 is offline
I get it too on windows after changing my user profile. It's a permissions issue that I just can't fix. So I ignore it.
Old July 26th, 2017, 04:59 PM
rjh's Avatar
rjh rjh is offline
I will move the writing of that file to your documents folder.
HSTouch Server Plugin Release Notes rjh HS3Touch Server Plug-in 41 April 22nd, 2017 01:18 PM
Release Notes NicolaiL izDaikin Plug-In 0 November 18th, 2014 06:24 PM
Release Notes NicolaiL izHeatmiser Plug-In 0 November 18th, 2014 06:23 PM
2.0 release notes Rien du Pre Clients - Apple iPhone/iPod/iPad 3 December 27th, 2010 09:40 AM
3.0.2.4 Release Notes JustinGould WapSeer (3P) 0 June 17th, 2006 06:43 PM
