Go Back   HomeSeer Message Board > Developer Support > Programming & Plug-in Development > Plug-In Development
Plug-In Development Discussions related to development new HomeSeer plug-ins.
Old October 20th, 2015, 07:19 AM
Moskus's Avatar
Moskus Moskus is offline
HSPI_MoskusSample - An easier plugin sample [VB.NET]
The wait is finally over!
I'm releasing my simple basic plugin sample, so that others can get started with writing plugins and (hopefully) contribute to the sample. I'll be adding elements as I get to them writing my own plugins.
The plugin is based on the samples from HomeSeer Tech, but I've added comments from the SDK and online help (and links to it so that it's easier accessible), I've renamed many variables to make them more compliant with newer naming conventions and make them easier to read and understand what's really going on (I am of course not able to rename classes from HS3, so there's a few strange things like "strTrigActInfo" which is not a string at all). I've also added a few elements to make coding easier (like a custom Settings class and functions to handle Linq on Devices and Events).
The samples and APIs from HomeSeer are really totally awesome! The versatility and integration is quite unique, and that leaves endless possibilities. It's just that I found the samples from HST somewhat confusing to understand, and as there are virtually no comments, it was rather hard to get going. I figured the time I spent on understanding the sample could be put to good use, so that others will save some time.
I've stared a simple FAQ below.
Q: "What does this plugin do?"
A: Nothing very useful, it just does "something" to get you started. Heres a quick summary:
1. It generates a random value every X minutes or seconds (this Is user changeable by a settings page). This is used to show how triggers and conditions work. See the region "Trigger Interface".
2. It generates different types of devices, just to show how that could be done and how the plugin reacts to usage of the different controls (CAPI). See the sub "CheckAndCreateDevices".
3. It shows how text, values and even custom objects can be stored in a device, and how you create your own "Tab" on the device settings. See subs "ConfigDevice" and "ConfigDevicePost".
4. It has a simple settings page that demonstrate how you can update settings for your plugin.
Q: "What do I need?"
A: You need Visual Studio (Visual Studio Community Edition should work just fine), HomeSeer 3 running either locally or on a remote computer, some spare time (the more, the better), and an appetite for coding.
Q: "Where do I start?"
A: 1. Copy "HomeSeerAPI.dll", "HSCF.dll" and "Scheduler.dll" from your HS3 dir to into the dir of this project (extract the zip file first, of course).
2. Just start HS3 if its not running, and hit Debug in Visual Studio. Then youll see whats going on
3. Do some customization, I suggest start by naming your plugin. this is done several places:
a. In "utils.vb", see variables "IFACE_NAME" and "INIFILE".
b. See in "My Project" in the Solution, and change both
c. If you, like me, dont want the solution and project named "MoskusSample" you can edit the .vbproj and .sln files in notepad (but close Visual Studio first).
4. Then look into the "Plugin.vb" file. A good place like any other is to start by finding the sub "InitIO", whats where the plugin is initialized.
5. However, if you REALLY want to dive right in to it, find the "UpdateTimerTrigger" sub and read to the end.
Here's a screenshot of the devices the plugin creates:
The sample demonstrates a few different methods for creating devices and how to handle input and output of data.
Here's a screenshot of Event triggers and actions:
The sample has two Triggers. One without subtriggers and one with. Both can be used as a condition. See Enums "TriggerTypes" and "SubTriggerTypes" which I've added to make "(int) TrigInfo.TANumber" and "(int) TrigInfo.SubTANumber" more understandable.
I've just added one action, but most of the same logic applies also applies to actions.
This sample doesn't magically make writing plugins super easy. It still requires some time to understand how it is pieced together. But hopefully it will get you started.
If you know what you are doing and have comments of what I can do better, then please feel free to let me know. Share code if you can.
What is missing at the moment:
  • Public plugin functions
  • Public property get/set
  • Proper documentation for web page building (I'm not done yet)
And last:
If you want, you can always "tip" me via Paypal to "moskus a_t gmail d_o_t com" (where "a_t" = "@" and "d_o_t" = "."). It is not expected or required, but highly appreciated.
Download in the next post.
I've written a basic "Getting Started" post here.
HSPro 3.0.0.368, Z-NET with Z-wave plugin 3.0.1.136, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Are you Norwegian (or Scandinavian) and getting started with HomSeer? Read the "HomeSeer School"!
Old October 20th, 2015, 07:21 AM
Moskus's Avatar
Here's the download.
Changelog:
1.0.0: Initial release.
Old October 20th, 2015, 07:23 AM
MrMxyzptlk MrMxyzptlk is offline
Excellent work!
Old October 20th, 2015, 07:40 AM
Moskus's Avatar
Old October 20th, 2015, 08:21 AM
kriz83 kriz83 is offline
Many thanks !
I wish something like this in C# will be available too ...
Old October 20th, 2015, 08:23 AM
Moskus's Avatar
I'm thinking about converting it to C#. But I thougt I'd release the VB-version first.
(I'm actually a faster coder in VB than C#, but I'm getting more and more used to C# too.)
Old October 20th, 2015, 08:29 AM
TomTom's Avatar
TomTom TomTom is offline
Wow! This is VERY KIND of you.
It is one thing to take the time to make something like this, and a whole lot more when to try to share this( a lot more effort, time, and documentation).
It will be helpful to many, and one day, hopefully, I'll be able to use this 8p
Tom
Old October 20th, 2015, 09:50 AM
donstephens's Avatar
donstephens donstephens is offline
Sweet! Thanks.
Don
Old October 20th, 2015, 10:00 AM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
Thank you very much!
my vb coding is whatever google tells me
so you are saying switch to C#
is C# hard to learn? so I guess Ill have to "Google" C# tutorials and get my hands wet. I would love to be able to do stuff like this!
HS - HS3 Pro Edition 3.0.0.368
Plugins - BLLAN 2.0.38.0 | BLRF 2.0.93.0 | Concord 4 3.1.13.8 | HSTouch Server 3.0.0.68 | RFXCOM 30.0.0.36 | X10 3.0.0.36 | Z-Wave 3.0.1.150
DSteiNeuro DSteiNeuro is offline
Location: Audrey Land (Somewhere near San Diego CA USA)
Old October 20th, 2015, 02:31 PM
Moskus's Avatar
Originally Posted by donstephens View Post
Sweet! Thanks.
Originally Posted by DSteiNeuro View Post
You are all very welcome! Please report any problems and give me feedback.
If you are currently learning VB.net, then learn that first. If you use vb.net or C# is just a matter of habbit, do not let anyone tell you something else.
I've used VB for 15 over 15 years, so I'm still a better and faster coder in VB.net. The "professionals" don't like it, apparently it has too much text. But I like to program without thinking about the code, I want to keep my head on the actual problem (after all, I'm an engineer, MSc). "Dim counter as Integer" is easier to read than "int counter", especially when the expressions are longer (which most of them are!).
However, if you haven't started, you could just as well start with C#. C# has some nice little touches which aren't as well implemented in VB.net, like lambda expressions. In that case, it's actually the other way around: C# is easier to understand than VB.net.
And I guess that for professional programmes, the language doesn't really matter, so they prefer typing speed over readability. "Dim counter as Integer" is a much longer expression than "int counter" to type, so that's an immediate increase in productivity.
What matters most is how you use the .NET framework and all it's various libraries, and how you structure your code.
.... but that's just my $0.02.
Old October 20th, 2015, 02:43 PM
I havent started learning ANYTHING yet... when I said VB I should of clarified VBScript for my job functions (I support 4000 laboratory computers and I specialize in Symantec Management Platform 7.5 SP1 and going to 7.6 HF5 soon)
Old October 20th, 2015, 03:45 PM
Jingoro Jingoro is offline
This is awesome. Great work!
Old October 21st, 2015, 10:40 AM
Moskus's Avatar
VBscript is closer to VB.net than C#...
... and I don't really know what Symantec Management Platform is.
Old October 21st, 2015, 02:21 PM
tonlof's Avatar
tonlof tonlof is offline
Thumbs up
Hi Moskus, this is one of the best initiatives that have been made in the forum. Let's hope we get more interesting plugins from new developers. Great work.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old October 21st, 2015, 03:31 PM
im on
Introduction for the really challenged C# users... but we WILL get you there course
Old October 22nd, 2015, 02:25 AM
beerygaz's Avatar
beerygaz beerygaz is offline
Super Seer
Great work Moskus. My two most frustrating aspect after getting my head around the architecture, are:
1. Parsing query strings in PostBacks from the config, trigger and action pages, hardcoding the text names of controls seems messy
2. Building those pages with complex config pages / multiple controls. Adding endless lines of manually coded HTML seems so frustrating when there are so many good HTML editors out there.
Any thoughts on trying to abstract some of these painful process in a class wrapper to make life easier?
Old October 22nd, 2015, 07:41 AM
Moskus's Avatar
1. I'm not sure how you'll get around the need to name your controls. Or maybe I'm not getting what you're asking.
2. After I've gotten used to the way HS3 handles these pages, it does make sense. Yes, there is some quite good WYSIWYG editors out there, but they can't handle controls like this. Even Visual Studio or Blend does not handle jQueries like this do.
And remember: That is an option. If you want to build your pages in asp.net you still can!
Old October 22nd, 2015, 07:42 AM
Moskus's Avatar
That's the idea! Thanks for the support.
Old October 22nd, 2015, 08:43 AM
happnatious1's Avatar
happnatious1 happnatious1 is offline
For 1. I found that loading everything from control names to config settings into PED and then assigning them to variables when the plugin starts made a lot of sense.
For 2. I just struggled along until I got things functional (but it looks like cat vomit) So anything that can be helpful in building JQuery pages would be great.
HTML code is On
why is plugin name not showing up in the basic plugin sample wetlip HS3 Plug-In Development 2 July 14th, 2013 04:37 PM
VB .Net plugin sample Blade HS2 / HSPRO 29 January 16th, 2006 01:16 AM
