Ok, so today I open my garage and found a river of water coming from under my water heater. Sure enough tank had its last days. I have never changed a water heater in my life so I need some advice. Should I go with the tankless water heater or should I go with the tank model?
Currently my water heater was controlled by HS, It would shut off the power to it when the alarm was active. This method helped save a lot with the electric bill.
I also have to mention that my home is powered by solar panels, so my electric bill is almost cero (I have to pay for the meter $15,00)
So my question is, should I invest in a costly tankless water? Or should I go with a normal tank heater?
