Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old January 5th, 2017, 01:33 PM
mrhappy mrhappy is offline
LAMetric Time Plugin
All,
I've recently bought myself the LAMetric Time device which is some sort of cross between the old BetaBrite LED type signs but with a semi-colour screen, a wifi adaptor, a speaker and the ability to implement it's own applications to display time/weather/whatever you want. It has a local API and allows some degree of ability to send messages from software to it and this plugin will allow you to do this from HomeSeer so you can send your desired messages to the LED sign.
It has both a cloud API and a local API, I have implemented only the local API and as such the options available are slightly more limited (you cannot respond to button presses etc) but there are no complications as the data does not leave your network or need you to download anything. Also until I can sort it in the HS UI out you can only send single frame messages rather than multi frame ones, everything else should be implemented though. It is multi instance and it is one instance per device.
Not expecting there to be a huge demand for this but it is here if anyone wants it, thanks to Jakob for testing it for me. The plugin is and always will be FREE, however if you do wish to donate you are more than welcome to (absolutely no obligation to do so) - if only so I can buy more HA related stuff - Donation Link - https://www.paypal.me/krang
If anyone uses it please let me know how you get on.
Plugin is now in the updater
Documentation & Release Notes: Link
Old January 6th, 2017, 04:21 AM
tCC tCC is offline
Woop, great work man, really appreciate it!!
I've ordered a LaMetric in December, hope it'll arrive this month and I was afraid it was a useless piece of sh*t when reading their forums cause nothing was possible with the plastic box.
I guess your plugin will add the missing coolness
Hope to see more people are going to use this!
Old January 6th, 2017, 02:24 PM
I've got a mixed opinion on it, whilst I have kept it I have decided to use it as a display only, it is currently fixed to the top of my kitchen units as a means to display the news in the morning when I wake up. I don't know if the screen is a bit too small for that only time will tell.
Let me know how you get on and if you have any things I have missed.
Old January 6th, 2017, 03:47 PM
S-F's Avatar
S-F S-F is offline
Oh man! By the title I thought this was going to be a plugin for metric time: 10 hour day, 100 minute hour and 100 second minute.
Originally Posted by rprade View Post
Old January 18th, 2017, 06:45 PM
This plugin is now in the updater, I've released version .3 which now has support for multi frame message sending (there are now two event actions) which was a little testing but seems to work. Also some minor UI fixes.
The last firmware for the LAMetric seemed to imply that there has been changes to allow control of the unit via the local API, unfortunately those don't appear to be published yet but when they do I'll update the plugin accordingly.
Old January 19th, 2017, 02:08 PM
tCC tCC is offline
Nice, but still waiting for my LaMetric to arrive :S
Are other people using your plugin yet ?
Keep up the good work
Old January 19th, 2017, 03:27 PM
I just got ordered from Amazon I think they were in stock on there...Jakob Sand has tested it and says that it works and I also use it, in reality there is not a great amount particularly taxing in the plugin once I sorted out all of the JSON structures. If you can I would avoid the multi frame event action if you are only sending a single frame only because it stores potentially quite a bit in the event and may be slow to build. That particular action is probably one of the most complex I've seen in HS but does appear to work.
I have looked at upnp discovery of the unit but mine appears to not reply 100% to the upnp library that I have and considering the issues with Mono then I think it is just easier to keep the unit with a static IP address.
Old January 23rd, 2017, 02:30 PM
tCC tCC is offline
jan-23 19:28:23 Error Error, Creating plugin instance: HSPI_LAMETRIC3P.exe->Exception has been thrown by the target of an invocation.->The type initializer for 'HSPI_LAMETRIC3P.HSPI' threw an exception.
jan-23 19:28:22 Updater Install/Update of package LAMetric 3P failed.
jan-23 19:28:22 Updater Error Installation of package LAMetric 3P failed. Try disabling the plugin first, then re-try the update.
jan-23 19:28:22 Updater Error, package file not found: C:\Program Files (x86)\HomeSeer HS3\Updates3\LAMetric 3P0.0.0.3\LAMetric_Documentation.pdf
jan-23 19:28:22 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\docs\LAMetric_Documentation.pdf
jan-23 19:28:22 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\images\lam.png
jan-23 19:28:22 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_LAMETRIC3P.exe.config
jan-23 19:28:21 Updater Installing package LAMetric 3P
jan-23 19:28:21 Updater Update HSPI_LAMETRIC3P.exe downloaded successfully
jan-23 19:28:21 Updater Downloading update: LAMetric 3P
Old January 23rd, 2017, 02:39 PM
tCC tCC is offline
The .dll wasn't copied to the Bin\LAMetric folder (LAMetric folder didn't exist either afterwards)
And the .pdf file is missing in the zip
But will test now
Old January 23rd, 2017, 02:52 PM
But will test now
Thanks for trying and spotting that, I've moved away from distributing with documentation and all of the documentation is available here - http://s652164905.websitehome.co.uk/...px#LAMetric 3P
I think once it encounters an error then it does not try further hence it not installing the bin file. It would be great if you could let me know how you get on.
Old January 24th, 2017, 04:11 AM
tCC tCC is offline
Ola,
Working like a charm, nice
Using it for notifications in HS3 for now and does that job really good, thanks man!
Now let me see what else I can do with the LaMetric, would be handy to switch apps remotely and use custom notification sounds.
Old January 24th, 2017, 05:06 AM
tCC tCC is offline
Played for a total of one hour with the LaMetric and the thing is way to tiny to be useful for anything else than short notifications, I'll use it for that than?
[edit]maybe it's somewhat useful afterall since we can use replacement variables in notifications[/edit]
Old January 24th, 2017, 03:09 PM
Yeah I wouldn't be doing too much text on it although there is the option to repeat messages a number of times, I've kept my notifications simple in that it might be a simple back/front door open type thing.
Local control of the unit is coming, they have apparently updated the firmware to cater for this but not yet released the documentation which should hopefully be this month. Once it is released then I'll look at integration. I think custom sounds are on the development list also.
Thanks for testing and appreciate the feedback.
Old January 25th, 2017, 03:17 AM
tCC tCC is offline
jan-25 07:58:32 LaMetric 3P LaMetric Web Exception: The operation has timed out
Since a couple of hours I get this message when an event is triggered where I sent a LaMetric notification, no notification is beeing shown.
When restarting the plugin I get:
jan-25 08:06:44 LaMetric 3P LAMetric Time Device Connection Failed
jan-25 08:06:44 LaMetric 3P LaMetric SendWebCommand Exception: Object reference not set to an instance of an object.
jan-25 08:06:44 LaMetric 3P LaMetric Web Exception: The operation has timed out
jan-25 08:06:41 LaMetric 3P API Key Disovered: blabla
jan-25 08:06:41 Plug-In Finished initializing plug-in LaMetric 3P
jan-25 08:06:41 LaMetric 3P IP Address Discovered: 192.168.1.129
jan-25 08:06:41 LaMetric 3P Getting IP Address For Instance
jan-25 08:06:41 LaMetric 3P Connection Worker Thread Started
jan-25 08:06:41 LaMetric 3P Icons In Table: 1
jan-25 08:06:41 LaMetric 3P Adding Icons To Table
jan-25 08:06:41 LaMetric 3P Registering Web Pages
jan-25 08:06:41 LaMetric 3P Devices Exist For Instance: False
jan-25 08:06:39 LaMetric 3P LAMetric Time Plugin Started
jan-25 08:06:38 Info Plugin LaMetric 3P has connected. IP:127.0.0.1:62673
jan-25 08:06:32 Info Plugin LaMetric 3P with instance: has disconnected
jan-25 08:06:32 Plug-In Shutting down Plug-In: LaMetric 3P
Problem is I cannot ping the unit. After some time it does reply to ping but with slow reponse times, the unit is also showing the looking for wifi icons, while my smartphone LaMetric app shows Signal strength Excellent, sigh
Will cycle power...
Old January 25th, 2017, 03:35 AM
tCC tCC is offline
Still buggy, cannot connect from my smartphone app as well:
64 bytes from 192.168.1.129: icmp_seq=0 ttl=64 time=71.919 ms
64 bytes from 192.168.1.129: icmp_seq=1 ttl=64 time=5.313 ms
64 bytes from 192.168.1.129: icmp_seq=2 ttl=64 time=7.198 ms
64 bytes from 192.168.1.129: icmp_seq=3 ttl=64 time=8.232 ms
64 bytes from 192.168.1.129: icmp_seq=4 ttl=64 time=581.130 ms
64 bytes from 192.168.1.129: icmp_seq=5 ttl=64 time=6.413 ms
64 bytes from 192.168.1.129: icmp_seq=6 ttl=64 time=178.054 ms
64 bytes from 192.168.1.129: icmp_seq=7 ttl=64 time=6.572 ms
64 bytes from 192.168.1.129: icmp_seq=8 ttl=64 time=138.241 ms
64 bytes from 192.168.1.129: icmp_seq=9 ttl=64 time=6.521 ms
64 bytes from 192.168.1.129: icmp_seq=10 ttl=64 time=143.481 ms
64 bytes from 192.168.1.129: icmp_seq=11 ttl=64 time=13.058 ms
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
64 bytes from 192.168.1.129: icmp_seq=15 ttl=64 time=497.884 ms
64 bytes from 192.168.1.129: icmp_seq=16 ttl=64 time=9.715 ms
64 bytes from 192.168.1.129: icmp_seq=17 ttl=64 time=5.410 ms
64 bytes from 192.168.1.129: icmp_seq=18 ttl=64 time=451.616 ms
64 bytes from 192.168.1.129: icmp_seq=19 ttl=64 time=6.313 ms
64 bytes from 192.168.1.129: icmp_seq=20 ttl=64 time=135.496 ms
64 bytes from 192.168.1.129: icmp_seq=21 ttl=64 time=7.793 ms
64 bytes from 192.168.1.129: icmp_seq=22 ttl=64 time=632.857 ms
64 bytes from 192.168.1.129: icmp_seq=23 ttl=64 time=9.220 ms
64 bytes from 192.168.1.129: icmp_seq=24 ttl=64 time=12.104 ms
Will try another wifi router this evening
Old January 25th, 2017, 01:46 PM
tCC tCC is offline
Weird, rebooted my router and the LaMetric is working again, had to restart the plugin because it didn't heal itself
Old January 25th, 2017, 01:47 PM
I'm going to hope it is a network connection issue rather than a plugin issue, I did have some initial issues which came about to my WiFi extender and AP isolation mode. Once I sorted that out it seemed to work just fine, interesting that you seem to get high ping rates and then very low ones, what other apps are you running on it?
Old January 25th, 2017, 01:49 PM
Hope it is all sorted now - I'll look at adding a auto reconnect for the future releases.
Old January 26th, 2017, 02:42 AM
tCC tCC is offline
Besides the default apps I have "Dark", "IFTTT Indicator" and "IFTTT Button" installed, auto scrolling the apps "Clock", "Weather" and "Stock Quotes" from 07:30 till 20:00, using Clock as screensaver in between.
Maybe my WiFi router had updated itself (using Portal WiFi without any logging) and did the LaMetric switch to another band or something (1 SSID for both 2.4 and 5Ghz).
But still working, ping are still fluctuating tho.
I'll let you know after a couple of days, thanks for your reply
Old January 28th, 2017, 06:38 PM
tCC tCC is offline
Still working
Historical/time based logging Plugin for ZEE S2 Amigo HomeSeer General Discussion Area 0 June 28th, 2016 07:21 PM
New devices created each time plugin is started Agwan HS3 Plug-In Development 3 August 25th, 2015 05:49 PM
rain8 plugin stops working after some time in hs3 wadams Rain8Net 4 August 16th, 2015 09:50 AM
Plugin really slows down response time chadg Motion Sensor Plug-In 19 January 18th, 2007 04:02 PM
