Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old February 2nd, 2017, 02:28 PM
MJackson MJackson is offline
Nanoleaf Aurora
Has anyone seen or heard of this yet? It is really cool looking.
https://nanoleaf.me/en/
Old February 2nd, 2017, 03:55 PM
ckellyusa's Avatar
ckellyusa ckellyusa is offline
I have them in my house, I really like them. They're coming out with new connectors and accessories for them too, later this year.
Old February 2nd, 2017, 03:58 PM
Awesome. How do you integrate them?
Old February 2nd, 2017, 04:01 PM
ckellyusa's Avatar
Currently they only work with the app and apple home kit stuff. An Alexa skill was just released (I haven't played with it yet) and IFTTT integration is in Beta. I haven't really tried to integrate it into HomeSeer yet, but they seem to have a lot of cool features coming!
Old February 2nd, 2017, 04:10 PM
Thanks, I think I am going to get some for my birthday (or earlier)... So many projects... Only so much money...
Old September 16th, 2017, 06:44 PM
ckellyusa's Avatar
Anyone interested in writing a plug-in for these? They have their API available now, is that all that is required?
https://nanoleaf.me/en/consumer-led-...eaf-local-api/
Old September 17th, 2017, 03:23 AM
mrhappy mrhappy is offline
If it was a bit cheaper then I would buy a set and write a plugin for it but £200 is my oscilloscope I have promised myself , looking at the SDK then it would be fairly easy to write a plugin for it in HS as they are just standard HTTP calls so perhaps someone might pick this up for you.
Old September 17th, 2017, 04:11 AM
w.vuyk's Avatar
w.vuyk w.vuyk is offline
It seems these lights come in two flavors, WIFI and Zigbee. As for Zigbee, I am transforming my plugin to support more brands, as long they follow the ZigBee 3 standards.
The API that they publish now seems to be cloudbased only, that is something I stay far away from. But if they support 'standard' Zigbee, I can check if it could be incorporated in my JowiHue plugin in the future.
Wim
-- Wim
Plugins:RFXCOM, HSTouch Server, Squeezebox, BLGData, Restart, Jon00's Perfmon and Network monitor, WeatherXML, BLBackup, TenScripting, BC4, Pushover, PHLocation, JowiHue, Zwave, Sonos
650 devices ---- 336 events ----- 40 scripts
Old September 17th, 2017, 06:29 AM
w.vuyk's Avatar
Ok,
Checked in more details here: https://nanoleaf.me/en/consumer-led-...pecifications/
All smarter series lights of Nanoleaf are supporting Zigbee HA 1.2 and are controllable with the JowiHue plugin in combination with the Raspbee/Conbee (current beta of the plugin).
Except the Aurora, sadly, which only supports wifi and is thus following the cloud protocol.
To bad for the Aurora. But the good news is that the other smart lights are controllable already.
Wim
Old September 17th, 2017, 11:56 AM
ckellyusa's Avatar
Wim, thanks for looking into it.
I agree that that it's not ideal that the Aurora only supports wifi. :/ I'm currently using the HomeSeer IFTTT channel in order to simply turn it on and off as my hallway light for now.
Old January 10th, 2018, 11:36 PM
mminehan mminehan is offline
Has anyone had a play with the Nanoleaf API?
I can get it to retrieve values (state, effect brightness etc) using the GET syntax but I can't seem to control it with "PUT" commands.
I would be keen to know if anyone else has had a play with this API in HS.
Here's my GET script if anyone is interested:
Sub Main (ByVal Parm As Object)
' &hs.runScript("GetNanoleafStatus.vb",False,True)
Dim WebIp As String = "localnaonleafIPaddress:16021"
Dim Token As String = "enter your token here"
Dim WebAddress As String
Dim Result As String
Dim NanoleafPowerDevice As Integer = 2079
Dim NanoleafTestDevice As Integer = 2082
Dim NanoleafEffectDevice As Integer = 2081
Dim NanoleafBrightnessDevice As Integer =2083
' GET state, result will be something like {"value":true}
WebAddress = "http://" + WebIp + "/api/v1/" + Token + "/state/on"
Result = hs.URLAction(WebAddress, "GET", "", "")
hs.writelog ("Nano Test" , Result + " ")
If Result.Contains("false") Then
hs.SetDeviceValueByRef (NanoleafTestDevice, 0 , True)
Else
hs.SetDeviceValueByRef (NanoleafTestDevice, 100 , True)
End If
' GET brightness , result will be something like {"value":100,"max":100,"min":0}
WebAddress = "http://" + WebIp + "/api/v1/" + Token + "/state/brightness"
Result = onlyDigits (Result)
hs.SetDeviceValueByRef (NanoleafBrightnessDevice, Result , True)
' GET effect
WebAddress = "http://" + WebIp + "/api/v1/" + Token + "/effects/select"
Result = Result.replace ("""", "")
hs.SetDeviceString (NanoleafEffectDevice, Result , True)
End Sub
'Function to retrive value from string
Function onlyDigits(s As String) As Integer
Dim retval As String ' This is the return string. '
Dim i As Integer ' Counter for character position. '
' Initialise return string to empty '
retval = ""
For i = 1 To Len(s)
If Mid(s, i, 1) >= "0" And Mid(s, i, 1) <= "9" Then
retval = retval + Mid(s, i, 1)
Else If Mid(s, i, 1) = "," Then 'end if a comma
Exit For
End If
Next
' Then return the return string. '
onlyDigits = retval
End Function
iCore5 Win 10 Pro x64 SSD
HS3 Pro Edition 3.0.0.435 Windows
BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
Old January 16th, 2018, 09:13 PM
I got it working.
Turns out that the 'hs.URLaction' has problems with the PUT command. There are several posts about this problem. Here for example:
https://forums.homeseer.com/showthread.php?t=178424
https://forums.homeseer.com/showthread.php?t=180358
The solution is to use a stream writer. Check the posts above on how to do this.
Old January 20th, 2018, 11:13 PM
If anyone wants to have a look at my script that sets on/off, brightness and effect (uses value/status pairs) the script is attached. I'm not the best coder but it works. VB script.
Old January 22nd, 2018, 09:50 AM
theplant theplant is offline
Hi!
Can you describe a bit the configuration required. I'm thinking a virtual device and then launching the script when the device changes? How did you configure the device?
Old January 23rd, 2018, 12:11 AM
Yep...that's exactly what I did.
You have get a token from the nanoleaf first. I did this using CURL which you can download for Windows. Instructions are in the nano leaf API document (register with nanoleaf as a developer to get this).
Once you have the token set up 3 virtual devices (on/of, brightness and effect). When any one of these virtual devices changes HS runs the script. The effect virtual device needs to have value pairs set up with the exact effect names (scenes) from the app.
Of course this is asymmetric in that if you use the nanoleaf iOS or Android app HS does not change the virtual devices.
I'm not at home but if you get stuck I can send some screenshots.
M
Originally Posted by theplant View Post
Hi!
Old January 23rd, 2018, 02:02 PM
That went easier than i would of thought. Thanks for the script, works great. Can now the remove the IFTTT configuration that i had previously.
Old January 24th, 2018, 01:21 AM
Cool. Glad to help.
Maybe one day someone much more skilled than myself will write a proper plugin that read the stored effects and works in both directions.
But until then I'm happy with the basic script.
Cheers, M.
Old March 5th, 2018, 06:28 PM
bazyr bazyr is offline
Hi, thanks for the script -- I've just started with Homeseer and have a Nanoleaf Aurora that I'd love to integrate. Two dumb questions:
1) I have a Hometroller SEL PRO, will this still with with a VB script?
2) Is there any way to try and get the Aurora formally supported/have a plugin written for it? The reason I switched to Homeseer was its huge compatibility, so it's really disappointing to realise it doesn't support this!
Old March 6th, 2018, 01:46 PM
I'mnot familiar with the Hometroller, so not sure how you setup up scripts. My system runs on Windows so I just put the scriipts in the script folder. You'll have to search the forums to find out how to add scripts to a Hometroller.
And as far as a plugin goes, I'm not skilled enough to make plugins. You'll have to convince someone like Blade or Ultra to give it a go. A proper plugin would be awsome.
M
Old March 6th, 2018, 04:17 PM
Price has gone down a bit looking at Amazon so I might purchase and write a plugin for it. I'm just trying to think of a suitable place for it to go, if I decide on it I'll post it back here.
aurora mutimedia fungun HomeSeer General Discussion Area 1 May 26th, 2004 08:13 AM
