Old June 9th, 2017, 08:33 AM
Moskus's Avatar
Moskus Moskus is offline
Smile IKEA Tradfri and HomeSeer -> TrådfriSeer!
IKEA is providing some very cheap but surprisingly good products with its Trådfri series. See here: http://www.ikea.com/us/en/catalog/ca...ighting/36812/
These bulbs are Zigbee, but can't be added to a Hue hub og Osram hub at the moment, but soon you can control the bulbs from HomeSeer using TradfriSeer and the (cheap) Tradfri gateway.
We're still adding a few features, and a public beta is available now!
Posibilities
- Supports all Trådfri bulbs
- White adjustable supports "Warm", "Normal" and "Cool"
- RGBW-bulbs have presets defined by Ikea (investigating this)
- Transition time is adjustable (I don't know the maximum value )
- "On Last Level" is finally working
- Basic control for groups is available (looking into more complex controls)
- Now expires on March 1st, 2018
Comming in the future
- Event Actions (for easier sunrise scenes for example)
Known bugs and limitations
- Requires a static IP for the hub, which usually means forcing your router to reserve the IP for the Trådfri hub
- After entering IP and Key, the plugin actually needs to be restarted in some cases (for some strange reason)
Installation
- Unpack zip file in your HS3 folder
- Activate under Plugins -> Manage
- Navigate to Plugins -> TradfriSeer -> Configuration and enter IP to the hub and the hub key (found on the bottom of the hub).
- Restart of the plugin is required (for some) after this
- Profit!
Changelog
- 0.0.1.5: Now supports DTLS for hubs with firmware > 1.2.0042
- 0.0.1.10: New +1 year expiration date. Various bug fixes.
HSPro 3.0.0.425, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Old June 9th, 2017, 10:11 AM
Elmstrom Elmstrom is offline
Seer Plus
Very interresting!
Old June 11th, 2017, 03:04 AM
lunkan lunkan is offline
This is great, will try direct when the beta is out! (and go to IKEA and shop trådfri)
Old June 14th, 2017, 06:04 AM
Moskus's Avatar
Getting closer and closer to open beta.
Just have a few kinks to iron out.
Int its current state the plugin only support bulbs, but not groups, switches or motion sensors. Groups will of course be added later, but I'm not sure what information we get for wireless switches and motion sensors.
Old June 14th, 2017, 11:46 AM
connoleg connoleg is offline
Looking forward to this...
Thanks Moskus, looking forward to getting HS integrated with my Tradfri setup.
Happy to help if you need.
G.
Old June 15th, 2017, 02:22 AM
FredrikKan FredrikKan is offline
Yes!
Have been waiting for this!
Old June 19th, 2017, 03:04 PM
Moskus's Avatar
Pssst! Scandinavians! See here: https://www.hjemmeautomasjon.no/file...dfriseer-beta/
Old July 5th, 2017, 03:07 AM
IanIreland's Avatar
IanIreland IanIreland is offline
Any news?
Looking at the prices I would be interested in this.
Old July 5th, 2017, 04:44 AM
Moskus's Avatar
Well, yeah. We have an "semi-open" beta going on, look in the link above (sorry, norwegian only, but Google Translate helps a little).
Old July 5th, 2017, 06:43 AM
IanIreland's Avatar
Thanks for the reply - Google isn't helping me so I guess I'll have to wait.
Old July 17th, 2017, 08:02 AM
gasm67 gasm67 is offline
Viewer
Hi, I've managed to get the add-in working (using Google Translate). Still a few issues to work out, but it seems to do what is required. Should further testing of Betas be required, I'll gladly assist.
Old July 22nd, 2017, 05:46 AM
Moskus's Avatar
The next version will include Groups, and when that is ready I'll post it here too.
Old August 2nd, 2017, 07:09 AM
beta working well here, thanks
Old September 6th, 2017, 11:52 AM
IanIreland's Avatar
FYI.
I now have the beta working.
I had to restart HS to get the bulbs recognised, I than had to restart HS again to get them functional.
I have one of the newer bulbs with varying colours. So far these do not appear, the bulb only shows Cool, Normal and Warm. The colours do work with the remote.
Old September 6th, 2017, 03:30 PM
Moskus's Avatar
Originally Posted by IanIreland View Post
FYI.
Then you have never bulbs than I can get hold of.
Can you try this version?
https://www.hjemmeautomasjon.no/foru...#comment-21168
It displays the config JSON for the bulbs at startup. Post it here, and I can try to add it.
Do you have a link to the bulb?
Old September 7th, 2017, 02:36 AM
RenderCAD's Avatar
RenderCAD RenderCAD is offline
Seer Plus
Hello
I'm very interested, and I will wait for the beta to try it. This could be an alternative to more expensive switches.
Massimo-RenderCAD
HomeSeer Version: HS3 Pro Edition 3.0.0.318 Operating System: Microsoft Windows 7 Professional - Work Station Number of Devices: 381 Number of Events: 210
Enabled Plug-Ins
3.0.0.29: ADIO-100
1.0.0.85: Arduino Plugin
2.0.3.0: BLDatabase
3.0.14.0: BLMediaPlayer
2.0.5.0: BLVolume
0.0.0.42: Current Cost 3P
0.0.0.3: Device Comparison 3P
1.2.0.0: Device History
3.0.0.33: EasyTrigger
5.0.0.58: Global Cache Pro
3.0.0.75: HSTouch Server
3.0.0.14: NetCAM
3.0.1.90: PHLocation
1.0.0.5: Restart
3.0.0.21: VWS
3.0.1.130: Z-Wave
Old September 7th, 2017, 07:15 AM
IanIreland's Avatar
I'll load the newer beta as soon as I get a moment. The Ikea bulb is Tradfri 703.389.51
OK - loaded up, where should the Json be displayed?
Old September 7th, 2017, 07:49 AM
Moskus's Avatar
If you enable debug logging it will be in the log. It should be enought to just hit the "rescan bulbs" button on the Settings page.
Old September 7th, 2017, 09:48 AM
IanIreland's Avatar
Here it is;
GetDeviceByID, got json-string: {"9054":0,"9001":"TRADFRI bulb E27 CWS opal 600lm","9002":1504705817,"9020":1504787613,"9003":65537,"575 0":2,"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","3":"1.3.002","6":1},"9019":1,"3311":[{"5850":1,"5709":35848,"5851":254,"5707":0,"5708":0,"5710":2 6214,"5711":0,"5706":"ebb63e","9003":0}]}
Old September 7th, 2017, 02:32 PM
Moskus's Avatar
Great, thanks! Will look into it!
