The following changes need to be made in order for your plugin to function properly with the HS3 version 3.0.0.333 or later.
If you reference the Newtonsoft JSON DLL in your plugin, make sure you install that dll in your own folder. Lets assume your plugin is named "AcmePlugin", your install.txt should install the Newtonsoft dll to:
bin\AcmePlugin
You should then include a exe.config file with the bin path set like so:
Note, many plugins are including the exe.config file and the bin path, but they are including "bin" before their own path, this is incorrect. Make sure "bin" is added after your private path.
bin\AcmePlugin
<probing privatePath="bin/AcmePlugin;bin" />
