Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > MyHS Remote Access Service
MyHS Remote Access Service Discussions regarding myHomeSeer Remote Access Service
Old August 30th, 2017, 07:43 AM
concordseer concordseer is offline
MyHS can't connect at the moment. Is the server down
I can't seem to connect to MyHS at the moment. Checked all the obvious. Is the server down.
Old August 30th, 2017, 07:53 AM
racerfern racerfern is offline
Down for me also.
Old August 30th, 2017, 07:59 AM
prnorton prnorton is offline
Mine is working fine.
}{ Phil }{
Old August 30th, 2017, 08:05 AM
gd1210's Avatar
gd1210 gd1210 is offline
Mine is down
Old August 30th, 2017, 08:09 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Working fine here on hstouch and web access.
Old August 30th, 2017, 08:12 AM
Pete's Avatar
Pete Pete is online now
Try a trace route across the pond and see where it stops?
Seeing spotty Amazon issues (routing through Dallas, Texas).
Automator
Old August 30th, 2017, 08:33 AM
mberger mberger is offline
Mine down too. At least it's not just me.
Old August 30th, 2017, 08:41 AM
Thanks guys. Only discovered it when Alexa refused to turn on the lights.
Thought we were going to get a heads up when there was problems with the service.
Old August 30th, 2017, 08:45 AM
YvMo YvMo is offline
Same here,s snce around 1am.
Old August 30th, 2017, 08:52 AM
Rupp's Avatar
Rupp Rupp is online now
Everyone please try again now and report back.
-Rupp
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
For some reason the server was limiting connections but our server check was connecting so we did not detect that it was down. I have restarted the service and all looks ok as of 8:51 AM. Investigating logs to see what happened.
Old August 30th, 2017, 09:02 AM
Back operational at this end. Alexa back doing what she is told lol thanks
Old August 30th, 2017, 09:09 AM
OK now, thanks.
Old September 1st, 2017, 12:22 PM
npa npa is offline
stopped working: saying email verification not working
mine stopped.. so my google homes are not working and are saying "homeseer is not responding"... when i try to log into myhsremote....i get "email verification not found.
Old September 1st, 2017, 01:34 PM
rjh's Avatar
rjh rjh is offline
Support is not busy right now, give us a call and they can probably clear things up, sounds like an issue with your account.
Old September 1st, 2017, 10:26 PM
npa npa is offline
just saw your reply, thanks for answering. will do Monday since support is closed for the weekend. thanks
Old September 2nd, 2017, 09:04 AM
rjh's Avatar
rjh rjh is offline
You can email support@homeseer.com, we check every day.
Help! HS3Touch can't connect using MyHS randman HS3Touch Clients - Apple IOS 13 January 19th, 2018 12:22 AM
Can not connect to myHS via HSTouch RBernier MyHS Remote Access Service 4 January 30th, 2015 03:13 PM
